Symptoms:
Board does not connect to Blynk server using SSL. I’m using the standard example:
It works fine when using the non-SSL version of Blynk. The board also works fine using the standard “WiFiClientSecure” example.
The log output looks like this:
[2664] Connected to WiFi
[2665] IP: 192.168.2.194
[2665]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
///_, /////_
/__/ v1.0.1 on ESP32
[2675] Connecting to blynk.cloud:443
[2896] Secure connection failed
[7676] Connecting to blynk.cloud:443
[7876] Secure connection failed
[12677] Connecting to blynk.cloud:443
[12880] Secure connection failed
• Hardware model + communication type: ESP32 via WiFi
• Smartphone OS: Android
• Blynk server: blynk.cloud:443
• Blynk Library version: 1.0.1
Code (I filled the credentials before compiling, of coarse):
You’ll need:
- Blynk IoT app (download from App Store or Google Play)
- ESP32 board
example.
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32_SSL.h>
char pass[] = "YourPassword";
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 443);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8443);
// to avoid delay() function!
