Dear Blynk Community!
I need help with my simple code. I would like to implement an auto restart feature when my ESP is disconnected from the server for longer than let’s say 3 minutes. Normally I would just hardcode a restart using millis function regardless for the connection status. However, for this project each time pin 15 is pulled High (and for some reason it is on restart) the bypass relay latches on disconnecting my bedroom lights from the main circuit. For obvious reasons I don’t want my lights blinking every few minutes and therefore I would like to execute the restart function only when ESP is offline for longer than 3 minutes or so.
Thanks !
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "XX";
char ssid[] = "XX";
char pass[] = "XX";
int RlyPin = 15;
int RlyState = LOW;
uint8_t led1 = 17;
int PWM_LED1;
int PWM_Count = 70; // Digital value needed to latch the relay (0-4095)
pinMode(RlyPin, OUTPUT);
ledcAttachPin(led1, 1);
ledcSetup(1, 12000, 12);
BLYNK_WRITE(V0) //slider in Virtual Pin 0 (0...4095)
PWM_LED1 = param.asInt();
ledcWrite(1, PWM_LED1); // 0-4095
float voltage1 = map(PWM_LED1, 0, 4095, 0, 330);
//Blynk.virtualWrite(V?, voltage1/100); Future voltage read
if (PWM_LED1 >= PWM_Count) {
RlyState = HIGH;
digitalWrite(RlyPin, RlyState);
Blynk.virtualWrite(V3, 4095); //turn on the widget on V3
RlyState = LOW;
Blynk.virtualWrite(V3, 0);
