Hi there! I’m new to using blynk and decided to use it for a school project. I’ve run into an issue where for some reason it will connect to WIFI for a second and them straight away disconnect. I’m not entirely sure how this issue became to be, but I would really like to get this working!
Error:
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13864
load:0x40080400,len:3608
entry 0x400805f0
[22] Connecting to nyoom
[624] Connected to WiFi
[624] IP:
[624]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.1.0 on ESP32
#StandWithUkraine https://bit.ly/swua
[634] Connecting to blynk.cloud:80
[1172] Ready (ping: 205ms).
ets Jun 8 2016 00:22:57
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805f0
[23] Connecting to nyoom
This constantly loops until I unplug the ESP32
Code:
#define BLYNK_TEMPLATE_ID "TMPLC-7OHXS6"
#define BLYNK_DEVICE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "TOKEN"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "SSID";
char pass[] = "PASS";
int WaterSensor = 26;
const int WaterPump = 0;
float volt = 0.0;
void sensor1(){
int value = analogRead(WaterSensor);
volt = (value);
Blynk.virtualWrite(V4,volt);
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
if(501>V4){
digitalWrite(WaterPump, HIGH);
else{
digitalWrite(WaterPump, LOW);
