Hi All,
I´m quite new in IOT projects, and I really appreciate if somebody can help me with a issue.
I create a project combining Blynk + OTA + espalexa using a NodeMcu ESP32S.
When ESP32 starts, everything runs perfectly (comand though Alexa or Blynk), but ramdonmly the blynk stop to work.
The interesting thing is that Internet conexion is ok and also Blynk does not lose the conection (Terminal keeps working ok).
Another issue is that, when I press the button (any virtual Pin) lot of times quickly, the ESP32 lost the blynk conection.
Here is my Code (just in case).
Thanks in advance.
Central da area da churrasqueira que controla:
Luzes fundo Jardim PIN 18
LEDS Churrasqueira PIN 19
Geladeira PIN 21
Luzes da Grelha PIN 22
Rega da Horta PIN 23 - com temporizador de segurança
#define BLYNK_TEMPLATE_ID "xxxxxxxxxx"
#define BLYNK_TEMPLATE_NAME "xxxxxxxxxxxxxxxx"
#define BLYNK_AUTH_TOKEN "xxxxxxxxxxxxxxxxx"
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "xxxxxxxxxxx";
char pass[] = "xxxxxxxxxxx";
#include <Ticker.h>
Ticker TerminalBlynk;
Ticker TimerSegurancaRegaHorta;
Ticker MedicaoHumidade;
Ticker TimerReset;
#define AOUT_PIN 36 //Sensor Humidade
const int AirValue = 3600; //you need to replace this value with Value_1
const int WaterValue = 1523; //you need to replace this value with Value_2
const int SensorPin = 15;
int soilMoistureValue = 0;
int soilmoisturepercent=0;
WidgetTerminal terminal(V1);
BLYNK_WRITE(V23) { //Rega da Horta
int x = param.asInt();
if (x == 1) {
digitalWrite(23, HIGH);
TimerSegurancaRegaHorta.attach(1200, TimerSeguranca);
if (x == 0) {
digitalWrite(23, LOW);
TimerSegurancaRegaHorta.detach();
BLYNK_WRITE(V22) { //Grelha
digitalWrite(22, param.asInt());
BLYNK_WRITE(V21) { //Geladeira
digitalWrite(21, param.asInt());
BLYNK_WRITE(V19) { //Leds Club Casablanca
digitalWrite(19, param.asInt());
BLYNK_WRITE(V18) { // Luzes Fundo Jardim
digitalWrite(18, param.asInt());
#include <ESPmDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <Espalexa.h>
void ReleRegaHorta(uint8_t brightness);
void ReleGrelha(uint8_t brightness);
void ReleGeladeira(uint8_t brightness);
void ReleLeds(uint8_t brightness);
void ReleLuzFundo(uint8_t brightness);
Espalexa espalexa;
void atualiza() {
int sinal = (WiFi.RSSI() * -1);
terminal.clear();
terminal.println(WiFi.SSID());
terminal.println(WiFi.localIP());
terminal.print("Sinal:: ");
terminal.print(sinal * -1);
if (sinal <= 67) {
terminal.println(" Excelente!");
} else if (sinal > 67 && sinal <= 70) {
terminal.println(" Bom!");
} else if (sinal > 70 && sinal <= 80) {
terminal.println(" Ruim!!");
} else if (sinal > 80) {
terminal.println(" Péssimo!!!");
terminal.flush();
TerminalBlynk.attach(5, atualiza);
pinMode(23, OUTPUT); //Rega da Horta
pinMode(22, OUTPUT); //Luzes Grelha
pinMode(21, OUTPUT); //Geladeira
pinMode(19, OUTPUT); //Leds
pinMode(18, OUTPUT); //Luz Fundo Jardim
pinMode(2, OUTPUT);
digitalWrite(22, LOW);
digitalWrite(21, LOW);
digitalWrite(19, LOW);
digitalWrite(18, LOW);
digitalWrite(2, LOW);
//OTA=======================================================
ArduinoOTA.setHostname("ESP32_Central_Club_Casablanca");
ArduinoOTA.setPassword("3289328800");
ArduinoOTA
.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH)
type = "sketch";
else // U_SPIFFS
type = "filesystem";
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
Serial.println("Start updating " + type);
.onEnd([]() {
Serial.println("\nEnd");
.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
espalexa.addDevice("Rega da Horta", ReleRegaHorta);
espalexa.addDevice("Luz da Grelha", ReleGrelha);
espalexa.addDevice("Geladeira", ReleGeladeira);
espalexa.addDevice("Leds", ReleLeds);
espalexa.addDevice("Luzes do Fundo do Jardim", ReleLuzFundo);
espalexa.begin();
MedicaoHumidade.attach(1800, MedirHumidade);
espalexa.loop();
ArduinoOTA.handle();
//digitalWrite(2, HIGH);
//if the connection to the stongest hotstop is lost, it will connect to the next network on the list
//=================================FUNCAO TIMER SEGURANCA REGA DA HORTA=====================================
void TimerSeguranca() {
Blynk.virtualWrite(V23, 0);
//==================================FUNCAO LIGAR RELE (Rega da Horta) ALEXA==================================
void ReleRegaHorta(uint8_t brightness) {
Serial.print("Device 1 changed to ");
if (brightness) {
Serial.print("ON, brightness ");
Blynk.virtualWrite(V23, 1);
Serial.println("OFF");
//==================================FUNCAO LIGAR RELE (Grelha) ALEXA==================================
void ReleGrelha(uint8_t brightness) {
if (brightness) {
digitalWrite(22, HIGH);
Blynk.virtualWrite(V22, 1);
Blynk.virtualWrite(V22, 0);
//==================================FUNCAO LIGAR RELE (Geladeira) ALEXA==================================
void ReleGeladeira(uint8_t brightness) {
if (brightness) {
digitalWrite(21, HIGH);
Blynk.virtualWrite(V21, 1);
Blynk.virtualWrite(V21, 0);
//==================================FUNCAO LIGAR RELE (Leds) ALEXA==================================
void ReleLeds(uint8_t brightness) {
if (brightness) {
digitalWrite(19, HIGH);
Blynk.virtualWrite(V19, 1);
Blynk.virtualWrite(V19, 0);
//==================================FUNCAO LIGAR RELE (Luzes Fundo Jardim) ALEXA==================================
void ReleLuzFundo(uint8_t brightness) {
if (brightness) {
digitalWrite(18, HIGH);
Blynk.virtualWrite(V18, 1);
Blynk.virtualWrite(V18, 0);
//====================================FUNCAO MEDIR HUMIDADE SOLO=================================================
void MedirHumidade() {
soilMoistureValue = analogRead(AOUT_PIN); //put Sensor insert into soil
Serial.println(soilMoistureValue);
soilmoisturepercent = map(soilMoistureValue, AirValue, WaterValue, 0, 100);
if (soilmoisturepercent > 100){
soilmoisturepercent = 100;
if (soilmoisturepercent < 0){
soilmoisturepercent = 0;
Blynk.virtualWrite(V36, soilmoisturepercent);
//======================================FUNCAO RESET ESP32=======================================================
void Reset(){
ESP.restart();
