Hi guys,
Please help. I’ve tried in many scenarios and find no way out so please advice.
I have ESP32 WEMOS Lolin with OLED and want to read the analog from thermistor value which connected to GPIO 13.
The output is always 4095 on the serial monitor and Blynk app virtual pin which is not correct value.
But when I comment out the “Blynk.begin(auth, ssid, pass);” and “Blynk.run();” , the output read just fine in the serial monitor.
I’ve tried to change from ESP32 board to UNO, the output is also read well in the serial monitor(and in the Blynk app by virtual pin).
So I am very in doubt why the analogRead doesn’t work with ESP32(when with Blynk) but works with UNO. Thanks.
//Here is the code for ESP32
#define inPin 13
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
timer.setInterval(1000L, TimerEvent);
void TimerEvent()
int sample = analogRead(inPin);
Serial.println(sample);
//Here is the code for UNO board
#define inPin A0
char auth[] = "xxxx";
Blynk.begin(Serial, auth);
void TimerEvent()
Blynk.virtualWrite(V5, sample);
