ESP32 DHT11/DHT22 Asynchronous Web Server (auto updates Temperature and Humidity) with led that It turns on when we click on a button in the applicaition
When I compile the code it’s success but when I upload it to the esp32 it give me this problem
The circuit of my project:
is connecting esp32 with sensor for tempreture DHT11 and connecting esp32 with led that should work by Blynk App.
I connet the output pin in the sensor with pin27 and (-) with ground and (+) with vcc (5volt)
And I connect the led with resistance
I connect the resistancewith ground and output(pin15)
And all of them connect with esp32
This is The code:
#include <WiFi.h>
#include "ESPAsyncWebServer.h"
const char* WIFI_NAME= "Anwar";
const char* WIFI_PASSWORD = "12345678";
WiFiServer server(80);
String header;
String LED_ONE_STATE = "off";
String LED_TWO_STATE = "off";
String LED_THREE_STATE = "off";
const int GPIO_PIN_NUMBER_22 = 22;
//const int GPIO_PIN_NUMBER_23 = 23;
//const int GPIO_PIN_NUMBER_15 = 15;
pinMode(GPIO_PIN_NUMBER_22, OUTPUT);
digitalWrite(GPIO_PIN_NUMBER_22, LOW);
Serial.println(WIFI_NAME);
WiFi.begin(WIFI_NAME, WIFI_PASSWORD);
Serial.print("Trying to connect to Wifi Network");
Serial.println("");
Serial.println("Successfully connected to WiFi network");
Serial.println("IP address: ");
server.begin();
void loop(){
WiFiClient client = server.available();
if (client) {
Serial.println("New Client is requesting web page");
String current_data_line = "";
while (client.connected()) {
if (client.available()) {
char new_byte = client.read();
Serial.write(new_byte);
header += new_byte;
if (new_byte == '\n') {
if (current_data_line.length() == 0)
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
if (header.indexOf("LED0=ON") != -1)
Serial.println("GPIO23 LED is ON");
LED_ONE_STATE = "on";
digitalWrite(GPIO_PIN_NUMBER_22 , HIGH);
if (header.indexOf("LED0=OFF") != -1)
Serial.println("GPIO23 LED is OFF");
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #4CAF50; border: 2px solid #4CAF50;; color: white; padding: 15px 32px; text-align: center; text-decoration: none; display: inline-block; font-size: 16px; margin: 4px 2px; cursor: pointer; }");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
// Web Page Heading
client.println("</style></head>");
client.println("<body><center><h1>ESP32 Web server LED controlling example</h1></center>");
client.println("<center><h2>Web Server Example Microcontrollerslab.com</h2></center>" );
client.println("<center><h2>Press on button to turn on led and off button to turn off LED</h3></center>");
client.println("<form><center>");
client.println("<p> LED one is " + LED_ONE_STATE + "</p>");
// If the PIN_NUMBER_22State is off, it displays the ON button
client.println("<center> <button class=\"button\" name=\"LED0\" value=\"ON\" type=\"submit\">LED0 Off</button>") ;
client.println("<button class=\"button\" name=\"LED0\" value=\"OFF\" type=\"submit\">LED0 ON</button><br><br>");
client.println("</center></form></body></html>");
client.println();
break;
else if (new_byte != '\r')
current_data_line += new_byte;
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
