ESP32 Connection Problems
I looked around in the forums but didn’t quite find the same Issue that I’ve been trying to figure out. I am currently running an Feather M0 Bluefruit LE with a Airlift FeatherWing ESP32 WiFi Coprocessor.
I am running the latest blynk library in the arduino IDE
I have been trying to use the example code to get the project to initially connect to the Blynk app but whenever I try to upload the code, I get the error “This code is intended to run on an ESP32 platform! Please check your tools->board settings”
I am still fairly new to WiFi programming so I just would like some guidance on how to get this project to connect. Does it have to do with trying to upload to the Bluefruit M0 LE that’s causing the problem? The wifi coprocessor doesnt have its own programming port and receives all of its info from the Bluefruit.
I have included the code I have tried to upload below.
Any help offered on this topic will be greatly appreciated.
thank you!
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example runs directly on ESP32 chip.
  Note: This requires ESP32 support package:
    https://github.com/espressif/arduino-esp32
  Please be sure to select the right ESP32 module
  in the Tools -> Board menu!
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID   "YourTemplateID"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "zbNzSvc_XmyaLnPjGA6JoIgbbEAvZbJQ";
char ssid[] = "ATTxqVbVbA";
char pass[] = "nuwtbc+w?frw";
If you hang around long enough and are very lucky, you might get an answer.
Your board combination isn’t in the list of supported hardware:
and to be honest, given the popularity and low price of ESP32 boards, you’d need to have a serious reason to want to use a niche (and expensive) board combination like yours.
