Getting an error in serial monitor,
Connecting to blynk.cloud 80
Invalid auth token.
The ESP32 is connected to my WIFI
More information required.
Usin a Wemos ESP32 D1 R32 board, following the steps in the initial quick start guide,
Can see the board connected to my wifi but its not connecting to the Blynk cloud.
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:13160
load:0x40080400,len:3036
entry 0x400805e4
[27] Connecting to
[4152] Connected to WiFi
[4153] IP:
[4153]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.1.0 on ESP32
#StandWithUkraine https://bit.ly/swua
[4163] Connecting to blynk.cloud:80
[4326] Invalid auth token```
Sketch used from the quickstart
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "TMPL333EYALD"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "xUtOWtEK-IaT8-Y4I_dw76AYNRs6DWu4"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = " ";
char pass[] = " ";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
@Richard1981 Please edit your posts, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your serial output and code so that they display correctly.
Did you copy/paste the Auth token from the web console, or type it manually?
Does the Auth token in your sketch exactly math the one displayed in the Device > Device Info > Firmware Configuration screen of your web console?
Are you using a VPN or other geolocation altering service on your home internet connection?
When you view the web console, do you see “Region: lon1” in the bottom right hand corner of the screen, and the same region as the prefix for the server in the About screen of the app?
Issue with Auth token, working thanks
