• Hardware model + communication type: ESP-32-Cam
• Android 9.1
• Blynk server
• Blynk Library version: 0.6.1 (I think)
Hi all,
I am trying to set up the ESP-32-Cam with a BME-280 all with Blynk.I had the BME working with a Nodemcu and Blynk, but moving over to the ESP-32-Cam is giving me trouble. The camera side seems to be working well, but the BME readings keep dropping in and out.I’m using GPIO 1 and 3 for I2C - but I have tried others as well with the same result.
The issue: The ESP-32 constantly drops the connection with the ESP-32-Cam and sends blank sensor readings (i.e. the reading intermittently shows the “blank” reading of 32 F). I don’t think it’s related to the camera running because I tried an older version of code with only the BME running.
I don’t really know what to try anymore. Prior to trying the old code, I also tried multithreading.
Finally, I don’t see any rules as to how to share code. This is the code: http://s000.tinyupload.com/?file_id=00808743002589477072 - that contains Adafruit_Sensor.h and similar files that conflicted with the camera code I borrowed and had to have “sensor_t” modified (I don’t believe it’s related since I do get some readings). I have also included the ‘main’ code below.
Thanks for the help!
#include <Blynk.h>
// #define BLYNK_PRINT Serial
#include <Wire.h>
// #include <DHT.h> // If you want to use a DHT sensor, uncomment this line
#include "Adafruit_Sensor.h">
#include "Adafruit_BME280.h" //If you use a DHT sensor, you can comment out this line
#include <math.h>
#include "src/OV2640.h"
#include <WiFi.h>
#include <WebServer.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT
//#define CAMERA_MODEL_ESP_EYE
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE
#define CAMERA_MODEL_AI_THINKER // This is the camera model for the ESP-32-Cam
#define I2C_SDA 3
#define I2C_SCL 1
#include "camera_pins.h"
// Authentication token from Blynk (provided when creating app, otherwise click the nut icon)
char auth[] = "REDACTED";
//Replace with your wifi name and password, exactly correct. If your wifi has a landing page (e.g. like trains and hotels that require you to sign in, this code will not work - I mention this for the one person who will go mad realizing this)
#define SSID1 "REDACTED"
#define PWD1 "REDACTED"
/* DELETE THE slash star on either side of this block of code to uncomment this section for water temperature sensor
// For measuring the temperature of water, we use a thermistor, this configuration is required. If you use a sensor/resistor with different characteristics, this will have to be modified.
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// how many samples to take and average, more takes longer
// but is more 'smooth'
// The beta coefficient of the thermistor (usually 3000-4000)
#define BCOEFFICIENT 3950
// the value of the 'other' resistor
#define SERIESRESISTOR 10000
const double VCC = 3.3; // NodeMCU on board 3.3v vcc
const double R2 = 10000; // 10k ohm series resistor
const double adc_resolution = 1023; // 10-bit adc
//This is the number of samples that will be taken for the water temperature sensor (to get an average and increase accuracy)
#define NUMSAMPLES 200
int samples[NUMSAMPLES];
OV2640 cam;
TwoWire I2CBME = TwoWire(0);
Adafruit_BME280 bme; // I2C
Adafruit_BME280 bme(BME_CS); // hardware SPI
Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
DHT dht(DHTPIN, DHTTYPE);
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
BME280 GND --> NodeMCU GND
BME280 3.3V --> NodeMCU 3V3
BME280 SDA --> NodeMCU D2
BME280 SCL --> NodeMCU D1 */
WebServer server(80);
const char HEADER[] = "HTTP/1.1 200 OK\r\n" \
"Access-Control-Allow-Origin: *\r\n" \
"Content-Type: multipart/x-mixed-replace; boundary=123456789000000000000987654321\r\n";
const char BOUNDARY[] = "\r\n--123456789000000000000987654321\r\n";
const char CTNTTYPE[] = "Content-Type: image/jpeg\r\nContent-Length: ";
const int hdrLen = strlen(HEADER);
const int bdrLen = strlen(BOUNDARY);
const int cntLen = strlen(CTNTTYPE);
void handle_jpg_stream(void)
char buf[32];
int s;
WiFiClient client = server.client();
client.write(HEADER, hdrLen);
client.write(BOUNDARY, bdrLen);
while (true)
if (!client.connected()) break;
cam.run();
s = cam.getSize();
client.write(CTNTTYPE, cntLen);
sprintf( buf, "%d\r\n\r\n", s );
client.write(buf, strlen(buf));
client.write((char *)cam.getfb(), s);
const char JHEADER[] = "HTTP/1.1 200 OK\r\n" \
"Content-disposition: inline; filename=capture.jpg\r\n" \
"Content-type: image/jpeg\r\n\r\n";
const int jhdLen = strlen(JHEADER);
void handle_jpg(void)
cam.run();
if (!client.connected()) return;
client.write(JHEADER, jhdLen);
client.write((char *)cam.getfb(), cam.getSize());
void handleNotFound()
String message = "Server is running!\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
server.send(200, "text / plain", message);
void sendSensor()
// float h = dht.readHumidity();
// float t = dht.readTemperature(true);
float t2inC = bme.readTemperature();
float t2 = (t2inC * 9 / 5) + 32; // convert to F from C
float h2 = bme.readHumidity(); //
float p = (bme.readPressure() / 100.0F);
//calculate VPD
float svp = 610.7 * (pow(10, (7.5*t2inC/(237.3+t2inC))));
float VPD = (((100 - h2)/100)*svp)/1000;
if (isnan(p) || isnan(t2) || isnan(h2) || isnan(t2inC)) {
// Serial.println("Failed to read from DHT sensor!");
return;
uint8_t i;
float average, TempinFzxs;
for (i=0; i< NUMSAMPLES; i++) {
samples[i] = analogRead(A0); //hear we read the water sensor
delay(50);
average = 0;
average += samples[i];
average /= NUMSAMPLES;
double Vout, Rth, temperature, adc_value;
float TempinF;
adc_value = average;
// adc_value = analogRead(A0);
Vout = (adc_value * VCC) / adc_resolution;
Rth = (VCC * R2 / Vout) - R2;
// Steinhart-Hart Thermistor Equation:
// Temperature in Kelvin = 1 / (A + B[ln(R)] + C[ln(R)]^3)
// where A = 0.001129148, B = 0.000234125 and C = 8.76741*10^-8
// temperature = (1 / (A + (B * log(Rth)) + (C * pow((log(Rth)),3)))); // Temperature in kelvin
// temperature = temperature - 273.15; // Temperature in degree celsius
// TempinF = (temperature * 9.0)/ 5.0 + 32.0;
// Blynk.virtualWrite(V5, t);
// Blynk.virtualWrite(V6, h);
Blynk.virtualWrite(V7, String(t2,2));
Blynk.virtualWrite(V8, h2);
Blynk.virtualWrite(V9, p);
Blynk.virtualWrite(V10, VPD);
// Blynk.virtualWrite(V13, String(TempinF, 2));
// Serial.begin(115200);
Blynk.begin(auth, SSID1, PWD1);
//Blynk.begin(auth, SSID1, PWD1, "blynk-cloud.com", 8442);
//Blynk.begin(auth, SSID1, PWD1, IPAddress(192,168,1,100), 8442);
I2CBME.begin(I2C_SDA, I2C_SCL, 100000);
bme.begin(0x76, &I2CBME);
// dht.begin();
timer.setInterval(6000L, sendSensor); // Frequency of updates
//while (!Serial); //wait for serial connection.
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
// Frame parameters
config.frame_size = FRAMESIZE_UXGA;
// config.frame_size = FRAMESIZE_QVGA;
config.jpeg_quality = 3;
config.fb_count = 2;
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
cam.init(config);
IPAddress ip;
WiFi.mode(WIFI_STA);
WiFi.begin(SSID1, PWD1);
while (WiFi.status() != WL_CONNECTED)
delay(500);
// Serial.print(F("."));
ip = WiFi.localIP();
// Serial.println(F("WiFi connected"));
// Serial.println("");
// Serial.println(ip);
// Serial.print("Stream Link: http://");
// Serial.print(ip);
//Serial.println("/mjpeg/1");
server.on("/mjpeg/1", HTTP_GET, handle_jpg_stream);
server.on("/jpg", HTTP_GET, handle_jpg);
server.onNotFound(handleNotFound);
server.begin();
server.handleClient();
