i believe the photo number is stored in the eeprom, it needs to be read each time, and add +1 to the photo numbers, so the same file name isnt used, and one photo overwrites the other
i have now added the blynk write and the libraries, good news v3 triggers the void, but serial says
Camera capture failed
Failed to capture picture
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include "FS.h"
#include "SD_MMC.h"
#include "esp_camera.h"
#include <EEPROM.h> // read and write from flash memory
// Select camera pin configuration
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
const char* ssid = "123";
const char* password = "123";
char auth[] = "123";
// define number of bytes to set aside in persistant memory
#define EEPROM_SIZE 1
int pictureNumber = 0;
static esp_err_t get_image(fs::FS &fs, const char * path) {
// Variable definitions for camera frame buffer
camera_fb_t * fb = NULL;
int64_t fr_start = esp_timer_get_time();
// Get the contents of the camera frame buffer
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Camera capture failed");
return ESP_FAIL;
// Save image to file
size_t fb_len = 0;
fb_len = fb->len;
File file = fs.open(path, FILE_WRITE);
if(!file){
Serial.println("Failed to open file in writing mode");
file.write(fb->buf, fb->len); // payload (image), payload length
Serial.printf("Saved file to path: %s\n", path);
file.close();
// Release the camera frame buffer
esp_camera_fb_return(fb);
int64_t fr_end = esp_timer_get_time();
Serial.printf("JPG: %uB %ums\n", (uint32_t)(fb_len), (uint32_t)((fr_end - fr_start)/1000));
return ESP_OK;
// Serial.setDebugOutput(true);
Serial.println();
WiFi.begin(ssid, password);
Blynk.begin(auth, ssid, password);
// Initial camera configuration
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG; // This is very important for saving the frame buffer as a JPeg
//init with high specs to pre-allocate larger buffers
if(psramFound()){
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
You may need to adjust these settings to get a picture you like.
Look in app_httpd.cpp in the CameraWebServer as an example on how these are used.
sensor_t * s = esp_camera_sensor_get();
int res = 0;
if(!strcmp(variable, "framesize")) {
if(s->pixformat == PIXFORMAT_JPEG) res = s->set_framesize(s, (framesize_t)val);
else if(!strcmp(variable, "quality")) res = s->set_quality(s, val);
else if(!strcmp(variable, "contrast")) res = s->set_contrast(s, val);
else if(!strcmp(variable, "brightness")) res = s->set_brightness(s, val);
else if(!strcmp(variable, "saturation")) res = s->set_saturation(s, val);
else if(!strcmp(variable, "gainceiling")) res = s->set_gainceiling(s, (gainceiling_t)val);
else if(!strcmp(variable, "colorbar")) res = s->set_colorbar(s, val);
else if(!strcmp(variable, "awb")) res = s->set_whitebal(s, val);
else if(!strcmp(variable, "agc")) res = s->set_gain_ctrl(s, val);
else if(!strcmp(variable, "aec")) res = s->set_exposure_ctrl(s, val);
else if(!strcmp(variable, "hmirror")) res = s->set_hmirror(s, val);
else if(!strcmp(variable, "vflip")) res = s->set_vflip(s, val);
else if(!strcmp(variable, "awb_gain")) res = s->set_awb_gain(s, val);
else if(!strcmp(variable, "agc_gain")) res = s->set_agc_gain(s, val);
else if(!strcmp(variable, "aec_value")) res = s->set_aec_value(s, val);
else if(!strcmp(variable, "aec2")) res = s->set_aec2(s, val);
else if(!strcmp(variable, "dcw")) res = s->set_dcw(s, val);
else if(!strcmp(variable, "bpc")) res = s->set_bpc(s, val);
else if(!strcmp(variable, "wpc")) res = s->set_wpc(s, val);
else if(!strcmp(variable, "raw_gma")) res = s->set_raw_gma(s, val);
else if(!strcmp(variable, "lenc")) res = s->set_lenc(s, val);
else if(!strcmp(variable, "special_effect")) res = s->set_special_effect(s, val);
else if(!strcmp(variable, "wb_mode")) res = s->set_wb_mode(s, val);
else if(!strcmp(variable, "ae_level")) res = s->set_ae_level(s, val);
Serial.println("Camera initialized!");
if(!SD_MMC.begin()){
Serial.println("Card Mount Failed");
uint8_t cardType = SD_MMC.cardType();
if(cardType == CARD_NONE){
Serial.println("No SD_MMC card attached");
Serial.println("SD Card Initialized");
void save(){
// initialize EEPROM with predefined size
EEPROM.begin(EEPROM_SIZE);
pictureNumber = EEPROM.read(0) + 1;
// Call function to capture the image and save it as a file
String path = "/picture" + String(pictureNumber) + ".jpg";
if(get_image(SD_MMC, path.c_str()) != ESP_OK ) {
Serial.println("Failed to capture picture");
} else{
Serial.println("Captured picture");
EEPROM.write(0, pictureNumber);
EEPROM.commit();
pinMode(4, OUTPUT);
digitalWrite(4, LOW);
BLYNK_WRITE(V3)
{int pinValue = param.asInt();
if (pinValue == 1) {
save(); }
