I am running the following code to get a doorbell camera working. Everything works well including notification on phone app except the captured image does not show in the app.
- I am using image Gallery to get photo
- I have data stream for photo with V0 / integer / default 0.
- I am using blynk2.0 with plus
#define BLYNK_TEMPLATE_ID "xxxx"
#define BLYNK_DEVICE_NAME "DoorBell"
#define BLYNK_AUTH_TOKEN "xxxx"
#include "esp_camera.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// WARNING!!! Make sure that you have either selected ESP32 Wrover Module,
// or another board which has PSRAM enabled
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT
//#define CAMERA_MODEL_ESP_EYE
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE
#define CAMERA_MODEL_AI_THINKER
#include "camera_pins.h"
#define LED 4
#define BUTTON 2
#define NETLED 13
const char* ssid = "********";
const char* password = "********";
char auth[] = "***************";
String my_Local_IP;
void startCameraServer();
void capture()
digitalWrite(LED,HIGH);
uint32_t number = random(40000000);
Serial.println("http://"+my_Local_IP+"/capture?_cb="+ (String)number);
Blynk.setProperty(V0, "url", "http://"+my_Local_IP+"/capture?_cb="+(String)number);
Blynk.logEvent("bell_ring");
digitalWrite(LED,LOW);
Blynk.begin(auth, ssid, password);
pinMode(LED,OUTPUT);
pinMode(NETLED,OUTPUT);
pinMode(BUTTON,INPUT);
Serial.setDebugOutput(true);
Serial.println();
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
//init with high specs to pre-allocate larger buffers
if (psramFound()) {
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
// camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
//initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1);//flip it back
s->set_brightness(s, 1);//up the blightness just a bit
s->set_saturation(s, -2);//lower the saturation
//drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
digitalWrite(NETLED, HIGH);
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
my_Local_IP = WiFi.localIP().toString();
Serial.println("' to connect");
//Blynk.begin(auth, ssid, password);
if(digitalRead(BUTTON) == LOW)
capture();
Any help is appreciated
