ESP32-CAM + Blynk: Device won't connect
Here’s another useful tips :
1- when you use blynk IOT, make sure that you are using the latest version of blynk library which is 1.0.1.
2- you should add " BLYNK_TEMPLATE_ID " and " BLYNK_DEVICE_NAME " on top of your sketch, above anything.
3- blynk.notify, blynk.email, and blynk.sms has been replaced with blynk.logEvent.
4- you should always keep your void loop as clean as possible, read this article
5-
I recommend you to read this article
