Hello there!
For my first time trying Blynk out, I am trying to make a project that has been done by a handful of people: a PIR sensor hooked to an ESP32-CAM that should alert my Blynk app whenever it goes HIGH and take pictures that are also displayed in the app.
I set-up the quickstart device and it worked perfectly. Went through the docs a bit and learned to use the digital pins of the ESP32, as well as read values in the Blynk app. Perfect.
However, when I tried to use the ESP32-CAM webserver alongside the Blynk app, the camera webserver will work just fine but my device will not connect. I was under the impression that, since what changed was that I am setting up the camera webserver on top of trying to connect to Blynk, perhaps both Blynk and the ESP32-CAM are trying to connect to the same address or something?
I am not very knowleadgable when it comes to IP Addresses, Ports, HTTP and whatnot, so I appologize for that. Do you guys recommend any possible solutions? By the way, this is a link to the code I am running
Thanks in advance!
