I m trying to put my project in place but still unsuccesfull.
I have read so many tutotorials and videos and still no luck .
I have connectedmy my esp 32 and uploaded an example from blynk page .Then added & created an account on blynk ,next managed to create a small widget project with a led .Finally got to the point where i cant go any further .when trying to connect to my blynk ap it says (wasnt off line ).I dont really understand what to do and how to find out if I`ve been connected to blynk app ? How to diagnose or verify it ?.
Im not __IT specialist therefore need a bit more patient .
Tried even to connect to my own local server but same story / (wasnt online yet ).
Please help gain more clarrifictaion about how to diagnose problems and learn more please .
Is this really what you did, in this sequence?
If so then it would be impossible to upload a sketch that contains your Blynk Auth code, as this requires you to create your Blynk account first.
Your best troubleshooting/debugging tool is the the serial monitor. What does it show?
And i assume that in section ssid need to use my wifi network + pass - password to it ??.
When i tried & still trying to connect via my local server i have the same problem . So if you`ll be happy to help my with solving and understanding that matter ill be extremally gratefull .
The “Invalid Auth token” message means that the Auth token you’ve entered into your sketch isn’t correct.
Did you copy/paste it from your email and ensure that there weren’t any leading/trailing spaces?
Ihave noticed that what youve mentioned but am 100% sure that it was copied /paste from email and can`t see any spaces missing or anything .like that .
Pete
i must have say that you are an awesome person you`ve just helped me sole my problem and finally connect to that lovely platform .
I will have another request , probably tomorrow or an other day . Ill be trying to connect via my local server so if you could help or assist me once again Ill be extremely grateful.
