im Having trouble to read my uv sensor value with blynk code. Im using the Guva s12sd with esp 32, it an analog sensor. The problem is that it always showing 0 on the serial monitor.
#define BLYNK_TEMPLATE_ID "T***K"
#define BLYNK_TEMPLATE_NAME "lynk"
#define BLYNK_AUTH_TOKEN "W***I"
#include <BlynkSimpleEsp32.h>
#include <WiFi.h>
char auth[]= BLYNK_AUTH_TOKEN;
const char ssid[] = "****";
const char password[] = "****";
const int SENSOR_PIN = 2;
//#define SENSOR_PIN 2
while (!Serial);
timer.setInterval(1000L, sendAnalog);
pinMode(SENSOR_PIN, INPUT);
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi");
Blynk.begin(auth, ssid, password);
int uvindex=0;
float sensorValue;
float sensorVoltage;
void sendAnalog()
sensorValue = analogRead(SENSOR_PIN);
sensorVoltage = sensorValue/4095*3.3;
if (sensorVoltage < 0.05) uvindex=0;
else if (sensorVoltage > 0.05 && sensorVoltage <= 0.227) uvindex = 1;
else if (sensorVoltage > 0.227 && sensorVoltage <= 0.318) uvindex = 2;
else if (sensorVoltage > 0.318 && sensorVoltage <= 0.408) uvindex = 3;
else if (sensorVoltage > 0.408 && sensorVoltage <= 0.503) uvindex = 4;
else if (sensorVoltage > 0.503 && sensorVoltage <= 0.606) uvindex = 5;
else if (sensorVoltage > 0.606 && sensorVoltage <= 0.696) uvindex = 6;
else if (sensorVoltage > 0.696 && sensorVoltage <= 0.795) uvindex = 7;
else if (sensorVoltage > 0.795 && sensorVoltage <= 0.881) uvindex = 8;
else if (sensorVoltage > 0.881 && sensorVoltage <= 0.976) uvindex = 9;
else if (sensorVoltage > 0.976 && sensorVoltage <= 1.079) uvindex = 10;
else if (sensorVoltage > 1.079 && sensorVoltage <= 1.170) uvindex = 11;
else uvindex = 0; //reading the sensor on A0
Blynk.virtualWrite(V4, uvindex); //sending to Blynk
Serial.print("sensor reading = ");
Serial.print(sensorValue);
Serial.println("");
Serial.print("sensor voltage = ");
Serial.print(sensorVoltage);
Serial.println(" V");
Serial.print("uvindex= ");
Serial.print(uvindex);
Serial.println();
Serial.println();
void loop(){
i tested th sensor alone and works fine with this code bellow :
float sensorValue;
int uvindex;
else uvindex = 0;
Serial.println("");
Serial.println();
Can anyone tell me where is the issue?
