Hi blynkers i need help with my esp32 …
- I can’t access to PWM option with app.
- I cant use the Bluetooth or BLE yet.
- There is no option to use the interne temperature sensor with app.
You’d normally do all of these things by writing and uploading code to your ESP32 so that it performs the functions you require in response to widget actions.
Are you trying to do this without code? If not, post your code here (correctly formatted with triple backticks of course).
Hello sir can i use the Wi-Fi and the Bluetooth of esp32 in the same time, means that using whatever i want BT or Wi-Fi without uploading the code each time.
1 code for two module’s?
