please i need help
when I reset esp32, my output 1 which was high became low, my output 2 which was low became high.
* TITLE: ESP32 Home Automation project using Blynk | Internet & Manual control with Realtime Feedback | 8-CHANNEL RELAY
* Click on the following links to learn more.
* YouTube Video: https://youtu.be/o1e5s_5p3FU
* Related Blog : https://iotcircuithub.com/blynk-esp32-home-automation/
* by Tech StudyCell
Update the Preferences > Aditional boards Manager URLs:
https://dl.espressif.com/dl/package_esp32_index.json, http://arduino.esp8266.com/stable/package_esp8266com_index.json
Note: This requires ESP32 support package:
https://github.com/espressif/arduino-esp32
Please be sure to select the right ESP32 module
in the Tools -> Board menu!
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
#define BLYNK_AUTH_TOKEN ""
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
#include <PCF8574.h>
#include <Wire.h>
#include <OneWire.h>
#define ONE_WIRE_BUS 15 // Your ESP8266 pin (ESP8266 GPIO 2 = WeMos D1 Mini pin D4)
char ssid[] = "";
char pass[] = "";
WidgetLED led1(V20);
WidgetLED led2(V21);
WidgetLED led3(V22);
WidgetLED led4(V23);
WidgetLED led5(V24);
WidgetLED led6(V25);
WidgetLED led7(V26);
WidgetLED led8(V27);
//Set i2c address
PCF8574 pcf8574(0x20);//input
PCF8574 pcf8574A(0x21);//output
PCF8574 pcf8574B(0x22);//output
PCF8574 pcf8574C(0x23);//input
// define the GPIO connected with Relays and switches
// Input channel of PCF8574
#define PUSH_BUTTON_1 P0 //P0 PCF8574
#define PUSH_BUTTON_2 P1 //P1 PCF8574
#define PUSH_BUTTON_3 P2 //P2 PCF8574
#define PUSH_BUTTON_4 P3 //P3 PCF8574
#define PUSH_BUTTON_5 P4 //P4 PCF8574
#define PUSH_BUTTON_6 P5 //P5 PCF8574
#define PUSH_BUTTON_7 P6 //P6 PCF8574
#define PUSH_BUTTON_8 P7 //P7 PCF8574
// Output channel of PCF8574A
#define RELAY_PIN_1 P0 //P0 PCF8574A
#define RELAY_PIN_2 P1 //P1 PCF8574A
#define RELAY_PIN_3 P2 //P2 PCF8574A
#define RELAY_PIN_4 P3 //P3 PCF8574A
#define RELAY_PIN_5 P4 //P4 PCF8574A
#define RELAY_PIN_6 P5 //P5 PCF8574A
#define RELAY_PIN_7 P6 //P6 PCF8574A
#define RELAY_PIN_8 P7 //P7 PCF8574A
// Output channel of PCF8574B
#define RELAY_PIN_9 P0 //P0 PCF8574B
#define RELAY_PIN_10 P1 //P1 PCF8574B
#define RELAY_PIN_11 P2 //P2 PCF8574B
#define RELAY_PIN_12 P3 //P3 PCF8574B
#define RELAY_PIN_13 P4 //P4 PCF8574B
#define RELAY_PIN_14 P5 //P5 PCF8574B
#define RELAY_PIN_15 P6 //P6 PCF8574B
#define RELAY_PIN_16 P7 //P7 PCF8574B
// Input channel of PCF8574C
#define PUSH_BUTTON_9 P0 //P0 PCF8574C
#define PUSH_BUTTON_10 P1 //P1 PCF8574C
#define PUSH_BUTTON_11 P2 //P2 PCF8574C
#define PUSH_BUTTON_12 P3 //P3 PCF8574C
#define PUSH_BUTTON_13 P4 //P4 PCF8574C
#define PUSH_BUTTON_14 P5 //P5 PCF8574C
#define PUSH_BUTTON_15 P6 //P6 PCF8574C
#define PUSH_BUTTON_16 P7 //P7 PCF8574C
#define VPIN_BUTTON_1 V12
#define VPIN_BUTTON_2 V13
#define VPIN_BUTTON_3 V14
#define VPIN_BUTTON_4 V15
#define VPIN_BUTTON_5 V16
#define VPIN_BUTTON_6 V17
#define VPIN_BUTTON_7 V18
#define VPIN_BUTTON_8 V19
#define VPIN_BUTTON_9 V22
#define VPIN_BUTTON_10 V23
#define VPIN_BUTTON_11 V24
#define VPIN_BUTTON_12 V25
#define VPIN_BUTTON_13 V26
#define VPIN_BUTTON_14 V27
#define VPIN_BUTTON_15 V28
#define VPIN_BUTTON_16 V29
#define OTA_HOSTNAME "Home_Automation"
void checkPhysicalButton();
int relay1State = LOW;
int pushButton1State = HIGH;
int relay2State = LOW;
int pushButton2State = HIGH;
int relay3State = LOW;
int pushButton3State = HIGH;
int relay4State = LOW;
int pushButton4State = HIGH;
int relay5State = LOW;
int pushButton5State = HIGH;
int relay6State = LOW;
int pushButton6State = HIGH;
int relay7State = LOW;
int pushButton7State = HIGH;
int relay8State = LOW;
int pushButton8State = HIGH;
int relay9State = LOW;
int pushButton9State = HIGH;
int relay10State = LOW;
int pushButton10State = HIGH;
int relay11State = LOW;
int pushButton11State = HIGH;
int relay12State = LOW;
int pushButton12State = HIGH;
int relay13State = LOW;
int pushButton13State = HIGH;
int relay14State = LOW;
int pushButton14State = HIGH;
int relay15State = LOW;
int pushButton15State = HIGH;
int relay16State = LOW;
int pushButton16State = HIGH;
int wifiFlag =0;
int analogInput = A0; // 0-25v voltage sensor is connected with the analog pin A0 of the arduino
//For 0-25v voltage sensor
float correctionfactor = 3.8;
float vout = 0.0;
float vin = 0.0;
// two resistors 30K and 7.5k ohm
float R1 = 30000; // 30 k ohms resistor value connected to +5v
float R2 = 7500; // 7.5 k ohms resistor value connected to ground.
int value = 0;
#define wifiLed 2 // D2
#define DHTPIN 3 // What digital pin we're connected to
//define DHTTYPE DHT11 // DHT11
#define DHTTYPE DHT22 // DHT22,AM2302,AM2321
//define DHTTYPE DHT21 // DHT21,AM2301
DHT dht(DHTPIN, DHTTYPE);
// This functiom sends Arduino's up time every second to Virtual Pin (5).
//In the app,Widget's reading frequency should be set PUSH.This means
//that you define how often to send data to Blynk App.
void sendSensor()
float h= dht.readHumidity();
float t= dht.readTemperature(); //or dht.readTemperature(true)for Fahrenheit
// if(isnan(h) || isnan(t)) {
// Serial.println("Failed to read from DHT sensor!");
// return;
value = analogRead(analogInput);
vout = (value * 5.0) / 1024; // see text
vin = vout / (R2/(R1+R2));
vin = vin - correctionfactor;
Blynk.virtualWrite(V0, t); // Virtual pin V0
Blynk.virtualWrite(V1, h); // Virtual pin V1
Blynk.virtualWrite(V2, vin); // Virtual pin V2
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
Blynk.syncVirtual(VPIN_BUTTON_3);
Blynk.syncVirtual(VPIN_BUTTON_4);
Blynk.syncVirtual(VPIN_BUTTON_5);
Blynk.syncVirtual(VPIN_BUTTON_6);
Blynk.syncVirtual(VPIN_BUTTON_7);
Blynk.syncVirtual(VPIN_BUTTON_8);
Blynk.syncVirtual(VPIN_BUTTON_9);
Blynk.syncVirtual(VPIN_BUTTON_10);
Blynk.syncVirtual(VPIN_BUTTON_11);
Blynk.syncVirtual(VPIN_BUTTON_12);
Blynk.syncVirtual(VPIN_BUTTON_13);
Blynk.syncVirtual(VPIN_BUTTON_14);
Blynk.syncVirtual(VPIN_BUTTON_15);
Blynk.syncVirtual(VPIN_BUTTON_16);
// Alternatively, you could override server state using:
// Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
// Blynk.virtualWrite(VPIN_BUTTON_2, relay2State);
// Blynk.virtualWrite(VPIN_BUTTON_3, relay3State);
// Blynk.virtualWrite(VPIN_BUTTON_4, relay4State);
// Blynk.virtualWrite(VPIN_BUTTON_5, relay5State);
// Blynk.virtualWrite(VPIN_BUTTON_6, relay6State);
// Blynk.virtualWrite(VPIN_BUTTON_7, relay7State);
// Blynk.virtualWrite(VPIN_BUTTON_8, relay8State);
// Blynk.virtualWrite(VPIN_BUTTON_9, relay9State);
// Blynk.virtualWrite(VPIN_BUTTON_10, relay10State);
// Blynk.virtualWrite(VPIN_BUTTON_11, relay11State);
// Blynk.virtualWrite(VPIN_BUTTON_12, relay12State);
// Blynk.virtualWrite(VPIN_BUTTON_13, relay13State);
// Blynk.virtualWrite(VPIN_BUTTON_14, relay14State);
// Blynk.virtualWrite(VPIN_BUTTON_15, relay15State);
// Blynk.virtualWrite(VPIN_BUTTON_16, relay16State);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
relay1State = param.asInt();
pcf8574A.digitalWrite(RELAY_PIN_1, relay1State);
Blynk.virtualWrite(V6,relay1State);
BLYNK_WRITE(VPIN_BUTTON_2) {
relay2State = param.asInt();
pcf8574A.digitalWrite(RELAY_PIN_2, relay2State);
Blynk.virtualWrite(V7,relay2State);
BLYNK_WRITE(VPIN_BUTTON_3) {
relay3State = param.asInt();
pcf8574A.digitalWrite(RELAY_PIN_3, relay3State);
Blynk.virtualWrite(V8,relay3State);
BLYNK_WRITE(VPIN_BUTTON_4) {
relay4State = param.asInt();
pcf8574A.digitalWrite(RELAY_PIN_4, relay4State);
Blynk.virtualWrite(V9,relay4State);
BLYNK_WRITE(VPIN_BUTTON_5) {
relay5State = param.asInt();
pcf8574A.digitalWrite(RELAY_PIN_5, relay5State);
Blynk.virtualWrite(V10,relay5State);
BLYNK_WRITE(VPIN_BUTTON_6) {
relay6State = param.asInt();
pcf8574A.digitalWrite(RELAY_PIN_6, relay6State);
Blynk.virtualWrite(V11,relay6State);
BLYNK_WRITE(VPIN_BUTTON_7) {
relay7State = param.asInt();
pcf8574A.digitalWrite(RELAY_PIN_7, relay7State);
Blynk.virtualWrite(V20,relay7State);
BLYNK_WRITE(VPIN_BUTTON_8) {
relay8State = param.asInt();
pcf8574A.digitalWrite(RELAY_PIN_8, relay8State);
Blynk.virtualWrite(V21,relay8State);
BLYNK_WRITE(VPIN_BUTTON_9) {
relay9State = param.asInt();
pcf8574B.digitalWrite(RELAY_PIN_9, relay9State);
Blynk.virtualWrite(V30,relay9State);
BLYNK_WRITE(VPIN_BUTTON_10) {
relay10State = param.asInt();
pcf8574B.digitalWrite(RELAY_PIN_10, relay10State);
Blynk.virtualWrite(V31,relay10State);
BLYNK_WRITE(VPIN_BUTTON_11) {
relay11State = param.asInt();
pcf8574B.digitalWrite(RELAY_PIN_11, relay11State);
Blynk.virtualWrite(V32,relay11State);
BLYNK_WRITE(VPIN_BUTTON_12) {
relay12State = param.asInt();
pcf8574B.digitalWrite(RELAY_PIN_12, relay12State);
Blynk.virtualWrite(V33,relay12State);
BLYNK_WRITE(VPIN_BUTTON_13) {
relay13State = param.asInt();
pcf8574B.digitalWrite(RELAY_PIN_13, relay13State);
Blynk.virtualWrite(V34,relay13State);
BLYNK_WRITE(VPIN_BUTTON_14) {
relay14State = param.asInt();
pcf8574B.digitalWrite(RELAY_PIN_14, relay14State);
Blynk.virtualWrite(V35,relay14State);
BLYNK_WRITE(VPIN_BUTTON_15) {
relay15State = param.asInt();
pcf8574B.digitalWrite(RELAY_PIN_15, relay15State);
Blynk.virtualWrite(V36,relay15State);
BLYNK_WRITE(VPIN_BUTTON_16) {
relay16State = param.asInt();
pcf8574B.digitalWrite(RELAY_PIN_16, relay16State);
Blynk.virtualWrite(V37,relay16State);
if (pcf8574.digitalRead(PUSH_BUTTON_1) == LOW) {
// pushButton1State is used to avoid sequential toggles
if (pushButton1State != LOW) {
// Toggle Relay state
relay1State = !relay1State;
// Update Button Widget
pushButton1State = LOW;
if (pcf8574.digitalRead(PUSH_BUTTON_2) == LOW) {
// pushButton2State is used to avoid sequential toggles
if (pushButton2State != LOW) {
relay2State = !relay2State;
pushButton2State = LOW;
if (pcf8574.digitalRead(PUSH_BUTTON_3) == LOW) {
// pushButton3State is used to avoid sequential toggles
if (pushButton3State != LOW) {
relay3State = !relay3State;
pushButton3State = LOW;
if (pcf8574.digitalRead(PUSH_BUTTON_4) == LOW) {
// pushButton4State is used to avoid sequential toggles
if (pushButton4State != LOW) {
relay4State = !relay4State;
pushButton4State = LOW;
if (pcf8574.digitalRead(PUSH_BUTTON_5) == LOW) {
// pushButton5State is used to avoid sequential toggles
if (pushButton5State != LOW) {
relay5State = !relay5State;
pushButton5State = LOW;
if (pcf8574.digitalRead(PUSH_BUTTON_6) == LOW) {
// pushButton6State is used to avoid sequential toggles
if (pushButton6State != LOW) {
relay6State = !relay6State;
pushButton6State = LOW;
if (pcf8574.digitalRead(PUSH_BUTTON_7) == LOW) {
// pushButton7State is used to avoid sequential toggles
if (pushButton7State != LOW) {
relay7State = !relay7State;
pushButton7State = LOW;
if (pcf8574.digitalRead(PUSH_BUTTON_8) == LOW) {
// pushButton8State is used to avoid sequential toggles
if (pushButton8State != LOW) {
relay8State = !relay8State;
pushButton8State = LOW;
if (pcf8574C.digitalRead(PUSH_BUTTON_9) == LOW) {
// pushButton9State is used to avoid sequential toggles
if (pushButton9State != LOW) {
relay9State = !relay9State;
pushButton9State = LOW;
if (pcf8574C.digitalRead(PUSH_BUTTON_10) ==LOW) {
// pushButton10State is used to avoid sequential toggles
if (pushButton10State != LOW) {
relay10State = !relay10State;
pushButton10State = LOW;
if (pcf8574C.digitalRead(PUSH_BUTTON_11) ==LOW) {
// pushButton11State is used to avoid sequential toggles
if (pushButton11State != LOW) {
relay11State = !relay11State;
pushButton11State = LOW;
if (pcf8574C.digitalRead(PUSH_BUTTON_12) == LOW) {
// pushButton12State is used to avoid sequential toggles
if (pushButton12State != LOW) {
relay12State = !relay12State;
pushButton12State = LOW;
if (pcf8574C.digitalRead(PUSH_BUTTON_13) == LOW) {
// pushButton13State is used to avoid sequential toggles
if (pushButton13State != LOW) {
relay13State = !relay13State;
pushButton13State = LOW;
if (pcf8574C.digitalRead(PUSH_BUTTON_14) == LOW) {
// pushButton14State is used to avoid sequential toggles
if (pushButton14State != LOW) {
relay14State = !relay14State;
pushButton14State = LOW;
if (pcf8574C.digitalRead(PUSH_BUTTON_15) == LOW) {
// pushButton15State is used to avoid sequential toggles
if (pushButton15State != LOW) {
relay15State = !relay15State;
pushButton15State = LOW;
if (pcf8574C.digitalRead(PUSH_BUTTON_16) == LOW) {
// pushButton16State is used to avoid sequential toggles
if (pushButton16State != LOW) {
relay16State = !relay16State;
pushButton16State = LOW;
void checkBlynkStatus() { // called every 3 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if(isconnected == false ){
wifiFlag =1;
digitalWrite(wifiLed,LOW);//Turn off Wifi LED
if (isconnected == true){
wifiFlag =0;
digitalWrite(wifiLed,HIGH);//Turn on Wifi LED
timer.setInterval(3000L, checkBlynkStatus); //check if Blynk server is connected every 3 seconds
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// Set up a function to be called every second
timer.setInterval(1000L,sendSensor);
pinMode(analogInput, INPUT);
pinMode(wifiLed,OUTPUT);
pcf8574.pinMode(PUSH_BUTTON_1,INPUT_PULLUP);
pcf8574.pinMode(PUSH_BUTTON_2,INPUT_PULLUP);
pcf8574.pinMode(PUSH_BUTTON_3,INPUT_PULLUP);
pcf8574.pinMode(PUSH_BUTTON_4,INPUT_PULLUP);
pcf8574.pinMode(PUSH_BUTTON_5,INPUT_PULLUP);
pcf8574.pinMode(PUSH_BUTTON_6,INPUT_PULLUP);
pcf8574.pinMode(PUSH_BUTTON_7,INPUT_PULLUP);
pcf8574.pinMode(PUSH_BUTTON_8,INPUT_PULLUP);
pcf8574C.pinMode(PUSH_BUTTON_9,INPUT_PULLUP);
pcf8574C.pinMode(PUSH_BUTTON_10,INPUT_PULLUP);
pcf8574C.pinMode(PUSH_BUTTON_11,INPUT_PULLUP);
pcf8574C.pinMode(PUSH_BUTTON_12,INPUT_PULLUP);
pcf8574C.pinMode(PUSH_BUTTON_13,INPUT_PULLUP);
pcf8574C.pinMode(PUSH_BUTTON_14,INPUT_PULLUP);
pcf8574C.pinMode(PUSH_BUTTON_15,INPUT_PULLUP);
pcf8574C.pinMode(PUSH_BUTTON_16,INPUT_PULLUP);
pcf8574A.pinMode(RELAY_PIN_1, OUTPUT);
pcf8574A.pinMode(RELAY_PIN_2, OUTPUT);
pcf8574A.pinMode(RELAY_PIN_3, OUTPUT);
pcf8574A.pinMode(RELAY_PIN_4, OUTPUT);
pcf8574A.pinMode(RELAY_PIN_5, OUTPUT);
pcf8574A.pinMode(RELAY_PIN_6, OUTPUT);
pcf8574A.pinMode(RELAY_PIN_7, OUTPUT);
pcf8574A.pinMode(RELAY_PIN_8, OUTPUT);
pcf8574B.pinMode(RELAY_PIN_9, OUTPUT);
pcf8574B.pinMode(RELAY_PIN_10, OUTPUT);
pcf8574B.pinMode(RELAY_PIN_11, OUTPUT);
pcf8574B.pinMode(RELAY_PIN_12, OUTPUT);
pcf8574B.pinMode(RELAY_PIN_13, OUTPUT);
pcf8574B.pinMode(RELAY_PIN_14, OUTPUT);
pcf8574B.pinMode(RELAY_PIN_15, OUTPUT);
pcf8574B.pinMode(RELAY_PIN_16, OUTPUT);
pcf8574A.digitalWrite(RELAY_PIN_1,relay1State);
pcf8574A.digitalWrite(RELAY_PIN_2,relay2State);
pcf8574A.digitalWrite(RELAY_PIN_3,relay3State);
pcf8574A.digitalWrite(RELAY_PIN_4,relay4State);
pcf8574A.digitalWrite(RELAY_PIN_5,relay5State);
pcf8574A.digitalWrite(RELAY_PIN_6,relay6State);
pcf8574A.digitalWrite(RELAY_PIN_7,relay7State);
pcf8574A.digitalWrite(RELAY_PIN_8,relay8State);
pcf8574A.digitalWrite(RELAY_PIN_9,relay9State);
pcf8574A.digitalWrite(RELAY_PIN_10,relay10State);
pcf8574A.digitalWrite(RELAY_PIN_11,relay11State);
pcf8574A.digitalWrite(RELAY_PIN_12,relay12State);
pcf8574A.digitalWrite(RELAY_PIN_13,relay13State);
pcf8574A.digitalWrite(RELAY_PIN_14,relay14State);
pcf8574A.digitalWrite(RELAY_PIN_15,relay15State);
pcf8574A.digitalWrite(RELAY_PIN_16,relay16State);
// Setup a function to be called every 100 ms
timer.setInterval(500L, checkPhysicalButton);
pcf8574.begin(); // push button
pcf8574A.begin(); // relay A output
pcf8574B.begin(); // relay B output
pcf8574C.begin(); // push button
timer.run();//Initiates Simple Timer
