I would need to see ECG chart on Blynk, can you adapt this cose for Blynk pls?
#include <WiFi.h>
#include <PubSubClient.h>
* Define Constants
#define VARIABLE_LABEL "sensor" // Assing the variable label
#define DEVICE_LABEL "esp32" // Assig the device label
#define SENSOR A0 // Set the A0 as SENSOR
char mqttBroker[] = "industrial.api.ubidots.com";
char payload[100];
char topic[150];
// Space to store values to send
char str_sensor[10];
* Auxiliar Functions
WiFiClient ubidots;
PubSubClient client(ubidots);
void callback(char* topic, byte* payload, unsigned int length) {
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
Serial.write(payload, length);
Serial.println(topic);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.println("Attempting MQTT connection...");
// Attemp to connect
if (client.connect(MQTT_CLIENT_NAME, TOKEN, "")) {
Serial.println("Connected");
Serial.print("Failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 2 seconds");
// Wait 2 seconds before retrying
delay(2000);
* Main Functions
WiFi.begin(WIFISSID, PASSWORD);
// Assign the pin as INPUT
pinMode(SENSOR, INPUT);
Serial.println();
Serial.print("Waiting for WiFi...");
Serial.print(".");
delay(500);
Serial.println("");
Serial.println("WiFi Connected");
Serial.println("IP address: ");
client.setServer(mqttBroker, 1883);
client.setCallback(callback);
if (!client.connected()) {
reconnect();
sprintf(topic, "%s%s", "/v1.6/devices/", DEVICE_LABEL);
sprintf(payload, "%s", ""); // Cleans the payload
sprintf(payload, "{\"%s\":", VARIABLE_LABEL); // Adds the variable label
float sensor = analogRead(SENSOR);
/* 4 is mininum width, 2 is precision; float value is copied onto str_sensor*/
dtostrf(sensor, 4, 2, str_sensor);
sprintf(payload, "%s {\"value\": %s}}", payload, str_sensor); // Adds the value
Serial.println("Publishing data to Ubidots Cloud");
client.publish(topic, payload);
client.loop();
delay(500);
