Hi Everybody , I used to work with esp01 with no problems in unloading sketches or operating it in normal state with RST , CH_EN pulled up with 2.2k ohm resistor (((An issue with esp8266 and relay))) …
BUT when trying to use esp12 with blynk 2 or even the previous version , the chip never connects to my WiFi or comes online, even it accepts codes and I tried the blink example and works well … I hope if any one have suggestions
I used two sketches and added my credentials authentication
this one
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "TMPLrkUi8kPy"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "hJBWyte4gU_Hz82nPark3OoVqX1yqzm9"
char pass[] = "YourPassword";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
AND THIS
BLYNK_WRITE(V0)
// Update state
BLYNK_CONNECTED()
void myTimerEvent()
Regards
