ok
see my code below:
#include <OneWire.h>
#define boiler 14
#define OnLed 4
#define systemLED 5
void buttonLedWidget();
void Temperature();
void LEDtoggle();
void OnTime();
void countTime();
int minutse = 0;
unsigned long minTime = 0;
unsigned long work2 = 0;
unsigned long nowTime = 0;
float ESP201ADCVref=1.10;
unsigned long count = 0;
char auth[] = "get from BLYNK";
WidgetLED led1(0);
WidgetLED led5(3);
//WidgetLED led4(16);
OneWire ds(2); // on pin 2 between VCC&DATA (a 4.7K resistor is necessary)
const int btnPin = 17;
WidgetLED led3(V3);
bool dudon = false;
bool dune = true;
bool manual = false;
int work = 0;
//************ Menu widget *************
BLYNK_WRITE(V1)
int getTime = 0;
switch (param.asInt())
case 1: // Item 1
Serial.println("off");
getTime = 0;
break;
case 2: // Item 1
Serial.println("30 minuts");
getTime = 30;
break;
case 3: // Item 2
Serial.println("45 minuts");
getTime = 45;
break;
case 4: // Item 3
Serial.println("60 minuts");
getTime = 60;
break;
case 5: // Item 4
Serial.println("75 minuts");
getTime = 75;
break;
case 6: // Item 5
Serial.println("90 minuts");
getTime = 90;
break;
case 7: // Item 6
Serial.println("120 minuts");
getTime = 120;
break;
default:
getTime = 0 ;
work = getTime;
// OnTime();
// Blynk.begin("1e0fc8aa350c47e88bbb078dc1f6302a", "LEDANI_2.4", "0522941258");
Blynk.begin("1e0fc8aa350c47e88bbb078dc1f6302a", "Nir&Rotem", "11335577");
// Blynk.begin("5a2d531baafa4c16855dfac4cbbc1275", "NIR", "11335577");
// Blynk.begin("1e0fc8aa350c47e88bbb078dc1f6302a", "hereO", "kgpswifi");
// Blynk.begin("1e0fc8aa350c47e88bbb078dc1f6302a", "iPhone", "123456789");
// attachInterrupt(digitalPinToInterrupt(0), pushButtton, CHANGE);
pinMode(boiler, OUTPUT);
pinMode(OnLed, OUTPUT);
pinMode(systemLED, OUTPUT);
digitalWrite(OnLed,HIGH);
digitalWrite(systemLED,LOW);
digitalWrite(boiler,HIGH);
timer.setInterval(200L, pushButtton);
timer.setInterval(10000L,Temperature);
timer.setInterval(100L,countTime);
timer.setInterval(10000L,OnTime);
timer.setInterval(10000L,sendTime);
while (Blynk.connect()==false)
Serial.println("try to connect");
led1.on();
//led4.on();
led5.on();
Blynk.virtualWrite(V1, "pick", 0);
bool lastbutton = 0;
int state = LOW; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW;
void pushButtton()
bool button = digitalRead(0);
Blynk_Delay(1);
bool button2 = digitalRead(0);
button = button && button2;
if(button && !lastbutton)
Serial.println("pressed");
if (state == HIGH)
state = LOW;
work = 130;
state = HIGH;
work = 0;
digitalWrite(V3, state);
lastbutton = button;
void Temperature()
Serial.println("Tempfunc");
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
//Serial.println("No more addresses.");
// Serial.println();
ds.reset_search();
delay(250);
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
Blynk_Delay(1000);
// delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) // we need 9 bytes
data[i] = ds.read();
int16_t raw = (data[1] << 8) | data[0];
if (type_s)
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10)
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
Serial.print("celsius: ");
Serial.println(celsius);
Blynk.virtualWrite(V5,celsius);
void OnTime()
unsigned long tout;
if((!dudon && dune) || work == 0 || (work == 130 && !dudon) )
work2 = work;
if(count < (work*600))
BoilerOn();
if((count >= (work*600)) && dudon)
Serial.println("tout");
BoilerOff();
Serial.print("work2: ");
Serial.println(work2);
if (dudon)
minTime = work2 - count/600;
Serial.print("minTime: ");
Serial.println((minTime));
nowTime = (count/600);
sendTime();
void sendTime()
unsigned long timeLeft = 0;
if(dudon &&((minTime > 0) && (work != 130))) timeLeft = (minTime);
if(minTime <= 0 )timeLeft = 0;
if(dudon && (minTime == 130))
Blynk.virtualWrite(V2,"ON");
else Blynk.virtualWrite(V2,timeLeft);
if(dudon &&((nowTime > 0))) Blynk.virtualWrite(V4,nowTime);
nowTime = 0;
Serial.print("timeLeft: ");
Serial.println(timeLeft);
Serial.print("nowTime: ");
Serial.println(nowTime);
void countTime()
if(dudon)
count++;
Serial.print("countTime:");
Serial.println(count);
else count = 0;
void BoilerOn()
digitalWrite(boiler,LOW);
digitalWrite(OnLed,LOW);
digitalWrite(systemLED,HIGH);
dudon = true;
count = 0;
Serial.println("dudon");
Blynk.notify("Boiler ON");
if(work == 130)Blynk.virtualWrite(V1, "pick", 0);
state = LOW;
void BoilerOff()
Serial.println("dudoff");
dudon = false;
Blynk.notify("Boiler OFF");
state = HIGH;
work = 0;
work2 = 0;
minTime = 0;
void Blynk_Delay(int milli)
int end_time = millis() + milli;
while (millis() < end_time){ }
