It is important for me to say that i tried 3 diffrent ones… all got the same error.
I also wanted to say that it worked. It worked fine. And then became unstable and stopped.
Arduino UNO with Esp01s
Blynk Library version 1.10
Connections:
esp01s arduino
tx---------------->pin2
rx---------------->pin3
3.3v------------->3.3v power supply arduino/external will detail ahead
ground--------->ground / external grouns
ch enable ----->3.3v
tried both arduino power source and external one.
will post the details of the one I found. wondering if it fitts.
baud rate both at 9600.
still getting the error message as you can see in the details ahead.
will add a the firmware of at version and also baud rate for proof.
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
You’ll need:
- Blynk IoT app (download from App Store or Google Play)
- Arduino Uno board
example.
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID "TMPLRVCXnAPS"
#define BLYNK_TEMPLATE_NAME "BALASH”
//// libraries included!
#include <ESP8266_Lib.h>
#include <AFMotor.h>
////WIFI STUFFFFFF
char ssid[] = "”
char pass[] = "”
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
///////END OF WIFI STUFFF
////THINGS WE CONTROL
const int RELAY_PIN = 13; // the Arduino pin, which connects to the IN pin of relay
// Number of steps per output rotation
// Change this as per your motor's specification
const int stepsPerRevolution = 48;
// connect motor to port #2 (M3 and M4)
AF_Stepper motor(stepsPerRevolution, 1);
// in Blynk app writes values to the Virtual Pin V1
BLYNK_WRITE(V1)
pinMode(RELAY_PIN, OUTPUT);
int pinValue1 = param.asInt(); // assigning incoming value from pin V1 to a variable
Serial.print(pinValue1);
if (pinValue1 ==1){
digitalWrite(RELAY_PIN, HIGH);
else{
digitalWrite(RELAY_PIN, LOW);
BLYNK_WRITE(V0)
int pinValue0 = param.asInt(); // assigning incoming value from pin V1 to a variable
if (pinValue0 ==1){
motor.step(100, FORWARD, INTERLEAVE);
BLYNK_WRITE(V2)
int pinValue2 = param.asInt(); // assigning incoming value from pin V1 to a variable
if (pinValue2 ==1){
motor.step(100, BACKWARD, INTERLEAVE);
// Set ESP8266 baud rate
motor.setSpeed(10);
//Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass);
Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass, "blynk.cloud", 80);
//Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
// to avoid delay() function!
details of the power supply:
MODEL:PH0301
INPUT:AC110-250V 50/60HZ
OUTPUT:DC3V-1A
my AT setup:
23:08:13.401 -> AT+UART_DEF=9600,8,1,0,0
23:08:13.401 ->
23:08:13.401 -> OK
23:08:23.180 -> AT+GMR
23:08:23.180 -> AT version:1.2.0.0(Jul 1 2016 20:04:45)
23:08:23.227 -> SDK version:1.5.4.1(39cb9a32)
23:08:23.274 -> v1.0.0
23:08:23.274 -> Mar 11 2018 18:27:31
23:08:23.274 -> OK
23:08:25.643 -> AT
23:08:25.643 ->
23:08:25.643 -> OK
and also i wanted to show the message i got:
22:58:53.398 -> ___ __ __
22:58:53.398 -> / _ )/ /_ _____ / /__
22:58:53.398 -> / _ / / // / _ \/ '_/
22:58:53.446 -> /____/_/\_, /_//_/_/\_\
22:58:53.492 -> /___/ v1.1.0 on Arduino Uno
22:58:53.492 ->
22:58:53.492 -> #StandWithUkraine https://bit.ly/swua
22:58:53.539 ->
22:58:53.539 ->
22:58:54.008 -> [647] Connecting to Eden Hamesucan
22:58:55.049 -> [1661] ESP is not responding
