Hi!
I am not an expert here but have 3 projects in Blynk. Two ESP32 and an Uno. I have the maker subscription. Suddenly it seems like only one can be online at the time. They all have different tokens.
Appreciate any help ![]()
You need to provide more info.
Have been using Blynk for a few years and was working on a new project that was online and working nicely with one other system at my cabin on line.
Then September 8th I was not able to get it on line again. I have tried to make a new device with a new token, connected to a new wifi ++ same result. My subscription I maker so I should have 10 device.
This is a bit over my level - normally Blynk has just worked.
You seem to be saying that when one device go online, it immediately kicks the other device off. Is that correct?
Does it happen immediately?
What does your serial monitor show when this happens?
Is it possible that your router has a limited DHCP pool, and that is causing the issue?
Have you tried rebooting your router?
The more relevant info you can provide, the sooner youโre likely to get a resolution.
Thanks Pete!
I run a full reset of the ESP as described by Chat GPT and all updates proposed - then it came back online ![]()
Thank for reading to post!
