The ESP_DoubleResetDetector library v1.0.1
has been updated and included into Arduino Library Manager and Platform.io
This library will help detect a double reset
within a configurable time, so that an alternative start-up mode / function
can be used. For example:
- To allow re-configuration of a device’s
WiFi / Blynk credentials
. - To do some
out-of-schedule work
, such asclearing data, loading defaults, etc.
The 4-byte flag data is stored in
- RTC Memory, EEPROM or SPIFFS for ESP8266
- EEPROM and SPIFFS for ESP32.
See example how to use this library in
[ConfigOnDoubleReset example] (https://github.com/khoih-prog/ESP_WiFiManager/blob/master/examples/ConfigOnDoubleReset/ConfigOnDoubleReset.ino)
This example demonstrates the open of ConfigPortal
whenever the reset button is pressed twice within 10 secs, so that you can change WiFi credentials, any stored data or do some out-of-schedule work
