BLYNK
ESP 32 : Temperature Monitoring with Blynk and Automatic Temperature Control using 2 Channel Relay Module
Detail :
MCU : ESP 32
Wired
DHT 22:
VCC : 3.3 V
Data : GPIO 4 / D4
GND : Gnd
Relay 2 Channel :
VCC : 5 V
IN1 : GPIO 12 / D12
IN2 : GPIO 13 / D13
GND : Gnd
Problem : DHT 22 didnt send any data to Blynk, but Blynk is Online.
#define BLYNK_AUTH_TOKEN            "------------------------------------"
#define WIFI_SSID "-----------------------------"             //Enter Wifi Name
#define WIFI_PASS "-------------------------t"         //Enter wifi Password
#include <BlynkSimpleEsp32.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <DHT.h>
int relay1 = 12;
int relay2 = 13;
DHT dht(4, DHT22);
float h = dht.readHumidity();
char ssid[] = "-------------------";// Your WiFi credentials.
char pass[] = "------------------";// Set password to "" for open networks.
void sendSensor()
    if (isnan(h) || isnan(t)) {
    Blynk.virtualWrite(V9, "Failed to read from DHT sensor!");
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
void relayonoff ()
  if (t >= 27.5 && t <= 29.5)  {
    digitalWrite(relay1, LOW);
    digitalWrite(relay2, LOW);
  else if (t <= 25 && t >= 27) { // Lampu Menyala
    digitalWrite(relay2, HIGH);
  else if (t >= 30 && t <= 32) { // Pompa Air Menyala
    digitalWrite(relay1, HIGH);
void display()
  if (relay1 == HIGH)  {
  Blynk.virtualWrite(V9, "Pompa Air Menyala");  //Water Pump On
  else if (relay2 == LOW)  {
  Blynk.virtualWrite(V9, "Lampu Halogen Menyala");  //Halogen Lamp On
  dht.begin();
  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  timer.setInterval(500L, relayonoff);
  timer.setInterval(500L, display);
Thanks For Your Time :bowing_man:
void sendSensor()
    return;
Sry, What do you suggest??
Your version of SendSensor() is missing the code to take temperature and humidity readings from the DHT sensor.
@Blynk_Coeur’s version adds this in, but re-declares the t and h variables as local, which won’t work correctly in the relayonoff function, so your SendSensor should look like this…
void sendSensor()
    return;
It makes no sense to call relay function every 500 ms
It’s better to integrate relay condition into sensor function.
It will never match :joy:
Okoke, I have edit it and ~
~I have try with just using DHT22 Modul it work but when i try DHT22 + Relay 2 Channel the DHT22 didnt send any data.
Thanks for showing it
What happens if t= 29.6 ? :thinking:
In this case, neither the lamp nor the water pump will be turned on as the temperature is outside the specified range.
Additionally, you have to add hysteresis to the system, which will cause the output to stay in one state until the input has changed by a certain amount, thus preventing rapid switching.
Maybe if you shared your latest code, and details of how you are powering your relays, we would have a better idea of the problem.
Thanks for the advice, i edit it and try. once more when i just use DHT22 Module its fine but when i use DHT22+Relay 2 Channel the DHT22 didnt send data.
#define BLYNK_AUTH_TOKEN            "MVL0V-6emdEBLETnnYMWS3ho7SvKVYxf"
//#define WIFI_SSID "TexasKost"             //Enter Wifi Name
//#define WIFI_PASS "eviudahpwt"         //Enter wifi Password
//#define BLYNK_TEMPLATE_ID           "TMPLv5vCaiaj"
//#define BLYNK_DEVICE_NAME           "Control relay"
#include <WiFi.h>
#include <DHT.h>
#define DHTPIN 4
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
int relay1 = 12;
int relay2 = 13;
int temperatureSensor = A0;
int thresholdLow = 25;
int thresholdHigh = 28;
char ssid[] = "TexasKost";// Your WiFi credentials.
char pass[] = "eviudahpwt";// Set password to "" for open networks.
void sendSensor()
    return;
  int temperature = analogRead(temperatureSensor);
  temperature = map(temperature, 0, 1023, 0, 100);
  if (temperature <= thresholdLow) {
  else if (temperature >= thresholdHigh) {
void display()
  dht.begin();
I don’t understand this code at all.
What sort of sensor is attached to your analog pin, and what is it used for.
What is its role compared to the DHT sensor, and why have you created variables called temperature and humidity instead of the t and h variables used to store the DHT readings?
I have change it =
#include <WiFi.h>
#include <DHT.h>
#define DHTPIN 4
int relay1 = 12;
int relay2 = 13;
void sendSensor()
    return;
  t = map(t, 0, 1023, 0, 100);
  if (t <= thresholdLow) {
  else if (t >= thresholdHigh) {
void display()
  dht.begin();
What’s the purpose of this line of code?
These lines that are near the top of the sketch should simply say…
float h; // humidity
float t; // temperature
Its say to change scale of censor data from 0-1023 to 0-100.
I have change my sketch, it work Blynk, Relay, Dht22. But there’s error when Temperature >= thresholdHigh Relay 1 is On, in sketch relay 2 should be On.
#define BLYNK_AUTH_TOKEN            "------------"
#include <WiFi.h>
#include <DHT.h>
#define DHTPIN 4
float h ;
float t ; // or dht.readTemperature(true) for Fahrenheit
int relay1 ;
int relay2 ;
#define relay1      13
#define relay2      14
void sendSensor()
    return;
void display()
  dht.begin();
Well, this piece of code makes no sense because you are using relay1 and relay2 as aliases for the pins the relays are connected to…
C++ treats LOW as 0 and HIGH as 1 so your void display() is actually being interpreted as…
void display()
  if (13 == 1)  {
  else if (14 == 0)  {
If you want to track the current status of each relay then you need to add two additional variables to do this.
Also, are your relays active HIGH or active LOW ?
Active high
i have change this Define to
int relay1 = 13; /D13
int relay2 = 14; /D14
I try this sketch now
#define BLYNK_AUTH_TOKEN            "----------------------------------"
#include <WiFi.h>
#include <DHT.h>
#define DHTPIN 4
float MinTemperature = 25;
float MaxTemperature = 28;
float h ;
int relay1 = 13;
int relay2 = 14;
//#define relay1      13
//#define relay2      14
void sendSensor()
    return;
  if (t <= MinTemperature) {
  else if (t >= MaxTemperature) {
  if (relay1 == 1)  {
  else if (relay2 == 0)  {
  dht.begin();
That it will make no difference to the functionality as you’ve not added additional variables to track the state of your relays.
Try re-reading what I wrote until you understand the point I was making.
