ESP-01 Not responding and dropping
Help needed,
I have adjusted my code to what I think is better for the blynk application but I am having trouble staying online and esp not responding. I have changed the baud rate to 9600 and yesterday the code and baud didnt match and it randomly started working. I’m really confused and have to hand up this project in 2 days.
Today Baud was changed to 9600 and was working but stopped at the next upload with no changes to ESP not responding. Any help really appreciated as my time is running out :frowning:
#include <util/delay.h>
#include <DHT.h>
#include <Wire.h>
#define pumptime 2500 //Pump on time
//BLYNK- APP and WEB requirements
#define BLYNK_TEMPLATE_ID "TMPL6Pv17xQ0"//
#define BLYNK_TEMPLATE_NAME "Greenhouse"//project name
#define BLYNK_AUTH_TOKEN "5j3T5Wy-3sapGdJpzz3F-T3AfyN-IKEN"
//Blynk Libraries
#include <ESP8266_Lib.h>
//BlynkTimer timer;
#define INTERVAL 5000L //5 sec timer
// Your WiFi details.
char ssid[] = "Fridgefi";
char pass[] = "xxxxxxx";
// For arduino Uno
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
// DHT parameters
#define DHTPIN 5
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// Arduino Pins
#define FAN 10 //enable Fan on pin 10
#define BULB  9 //enable Bulb on pin 9
#define PUMP  8  //enable pump on pump 8
#define RedLED1  7 //Red LED for water level
#define GreenLED1  4 //Green LED for water level
#define SoilMoisture  A1 //Soil Moisture Sensor
#define WaterLevel  A2// WaterLevel Sensor
//Virtual pins FOR BLYNK APP
#define V1_SOIL_MOISTURE V1
#define V2_WATER_LEVEL V2
#define V3_GREEN_LED V3
#define V5_Humidity V5
#define V6_Temperature V6
#define V7_RED_LED V7
#define V8_PUMP V8
#define V9_BULB V9
#define V10_FAN V10
const int SoilDry = 520; //Dry value of soil
const int SoilWet = 260; //Wet value of soil
 void getTemp(){
  // Read DHT11- Inside Greenhouse
int temperature = dht.readTemperature();// read the temp and assign the value to temperature
int humidity = dht.readHumidity();// read the humidity and assign the value to temperature
  Blynk.virtualWrite(V6_Temperature, temperature);
  Blynk.virtualWrite(V5_Humidity, humidity);
  Serial.print("Temp: ");
  Serial.println(temperature);
  Serial.print("Humidity: ");
  Serial.println(humidity);
  // Check if reads fails
  if (isnan(temperature) || isnan(humidity)) {// if not a number on temp or humidity return the error below
    //Serial.println(F("Failed to read from DHT sensor"));
    digitalWrite (RedLED1,HIGH);
    digitalWrite (GreenLED1,LOW);// turn on red LED for alarm
    return;
    if (temperature < 22) {
    digitalWrite(FAN, LOW);//Turn off the fan
    digitalWrite(BULB,HIGH);
    Blynk.virtualWrite(V9_BULB, HIGH);
    Blynk.virtualWrite(V10_FAN, LOW);
    else if(temperature > 23 ) {
    digitalWrite(FAN, HIGH);//Turn on the fan
    digitalWrite(BULB, LOW);//Turn off the bulb
    Blynk.virtualWrite(V9_BULB, LOW);
    Blynk.virtualWrite(V10_FAN, HIGH);
  void checkMoisture(){
 int SoilMoisture = analogRead (SoilMoisture);//read value of soil moisture
 int WaterLevel = analogRead (WaterLevel); //read value of waterlevel
 int SoilMoistpercent; // moisture value in percentage
 SoilMoistpercent = map(SoilMoisture,SoilWet,SoilDry,100,0); // To display the soil moisture value in percentage
 Blynk.virtualWrite(V1_SOIL_MOISTURE, SoilMoistpercent);
 Blynk.virtualWrite(V2_WATER_LEVEL, WaterLevel);
  Serial.print("WaterLevel: ");
  Serial.println(WaterLevel);
  Serial.print("SoilMoisture % is : ");
  Serial.println(SoilMoistpercent);
   if (SoilMoistpercent < 50 && WaterLevel > 350){
    digitalWrite (RedLED1,LOW);
    digitalWrite (GreenLED1,HIGH);
    digitalWrite (PUMP,HIGH);
    Blynk.virtualWrite(V7_RED_LED, LOW);
    Blynk.virtualWrite(V3_GREEN_LED, HIGH);
    Blynk.virtualWrite(V8_PUMP, HIGH);
    delay (pumptime);
    digitalWrite (PUMP,LOW);
    Blynk.virtualWrite(V8_PUMP, LOW);
 else if (WaterLevel < 340){
    digitalWrite (RedLED1,HIGH); //turn  on the red LED
    Blynk.virtualWrite(V7_RED_LED, HIGH);//Write to app
    digitalWrite (GreenLED1,LOW);//Turn off green led
    Blynk.virtualWrite(V3_GREEN_LED, LOW);//write to blynk
    digitalWrite (PUMP,LOW); //turn off pump
    delay(5000);//5 second delay
void mytimer(){// write on the timer ticks
Blynk.virtualWrite(V1_SOIL_MOISTURE, SoilMoisture);
Blynk.virtualWrite(V3_GREEN_LED, GreenLED1);
Blynk.virtualWrite(V7_RED_LED, RedLED1);
Blynk.virtualWrite(V8_PUMP, PUMP);
Blynk.virtualWrite(V9_BULB, BULB);
Blynk.virtualWrite(V10_FAN, FAN);
Blynk.syncVirtual(V1, V2, V3, V5, V6, V7, V8, V9, V10);// sync with app
  Serial.begin(9600);// for Blynk app
  // Set ESP8266 baud rate
  // Initialize Temp & Humidity Sensor
dht.begin();
//Blynk WIFI
Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass, "blynk.cloud", 80); //BLYNK app
//timer.setInterval(INTERVAL, getTemp);
 //Enable pinMode
//OUTPUTS//
pinMode (FAN, OUTPUT); //enable pin 10 as output
digitalWrite(FAN, LOW);//initial low
pinMode (BULB, OUTPUT); //enable pin 9 as output
digitalWrite(BULB, LOW);//initial low
pinMode (PUMP, OUTPUT); //enable pin 8 as output
digitalWrite(PUMP, LOW);//initial low
pinMode (RedLED1,OUTPUT);
digitalWrite(RedLED1, LOW);//initial low
pinMode (GreenLED1,OUTPUT);
digitalWrite(GreenLED1, LOW);//initial low
//INPUTS//
pinMode(SoilMoisture, INPUT); //enable pin A1 as input
pinMode(WaterLevel, INPUT);//enable pin A2 as input
//pinMode()
  Blynk.run();//Runs blynk
  getTemp (); //function for temp
  checkMoisture();//function for soil moisture
  timer.run();//Run the Blynk timer
These two lines need to come out of your void loop, and you need to call them with BlynkTimer interval timers.
You also need to remove the delays from these functions, as they will be redundant when you use BlynkTimer to set the frequency at which they are called.
In addition, this line of code should not be executed in your sketch. Fortunately the mytimer function that this is inside doesn’t seem to be called, and you should keep it that way…
I’m not sure what this is meant to do…
but it doesn’t sound like it will work well with Blynk.
As far as your baud rate issues are concerned, it’s difficult to make any sense of what you’ve written. More information would be needed to explore that issue.
Ok Thanks Pete. I will look at the suggestions. So if you can tell me do I call the timer in the setup like I have commented out ?
I have tried to upload a screen grab of what I am seeing. So it was working then with the next upload I get the ESP not connecting. This is happening a lot and I plug into the computer and check AT commands and fine.
Done what you suggested and working a lot smoother. Thank you .
Please copy and paste the text from your serial monitor, and use triple backticks like you do when posting code, rather than posting screenshots.
No problem, Can I use a delay at all when using blynk ? In this function I use a delay to define the pump on time, but now that you have said it to me I have an issue where the pump is staying on. Now has me thinking that it does not see the delay
    delay (pumptime);
If you want me to look at your code then you need to post the full sketch, not snippets.
If you want me to look at serial monitor output then you need to post it as text, with triple backticks, rather than screenshots.
Sorry, Thanks Pete. I have taken on board your suggestions and I have made changes to the timers and have added in the timer.enable(PUMPTIME); instead of delay having read over the documents but cannot test it yet due to the ESP not responding. Seem when I make a change and upload then I get ESP not responding. Sometimes I can disconnect and wait and it will come back but takes a few tries.
Again thank you for the support. Have included the new updated code
#include <avr/io.h>
#include <DHT.h>
#include <Wire.h>
//BLYNK- APP and WEB requierments
//Blynk Libraries
//BlynkTimer timer;
BlynkTimer timer;// enables blynk timer
#define INTERVAL 5000L//5 sec timer for functions(temp and soil moisture)
#define PUMPTIME 2500L // timer for pump on time
char pass[] = "arsenaL2005*";
// For arduino Uno
// DHT parameters
#define DHTPIN 5
// Arduino Pins
#define V8_PUMP V8
#define V9_BULB V9
#define V10_FAN V10
const int SoilDry = 524; //Dry value of soil
const int SoilWet = 254; //Wet value of soil
 void getTemp(){
    return;
    digitalWrite(BULB,HIGH);// turn on the bulb
   if (SoilMoistpercent < 90 && WaterLevel > 350){
    timer.enable(PUMPTIME); //timer for pump time, can be changed above
dht.begin();
//Blynk WIFI
timer.setInterval(INTERVAL, checkMoisture);
 //Enable pinMode
//OUTPUTS//
//INPUTS//
//pinMode()
