ESP-01 connects to Blynk and immediately disconnects
I wanted to connect to a server using Arduino Uno and an ESP-01 with an adapter that converts it into 4 pins (GND, VCC, TX, RX). It connects to the internet and even to the service itself, and the website shows it as being in “online” mode. I connected it using the quick start guide, where uptime is displayed. However, it connects and immediately disconnects, and the uptime value remains 0
  WARNING!
    It's very tricky to get it working. Please read this article:
    http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
  You’ll need:
   - Blynk IoT app (download from App Store or Google Play)
   - Arduino Uno board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID           "XXX"
#define BLYNK_TEMPLATE_NAME         "XXX"
#define BLYNK_AUTH_TOKEN            "XXX"
#include <ESP8266_Lib.h>
char ssid[] = "XXX";
char pass[] = "XXX";
#define EspSerial Serial1
SoftwareSerial EspSerial(2, 3); // TX, RX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 57600
ESP8266 wifi(&EspSerial);
  Serial.begin(57600); // Serial Monitor at 57600 baud
  // Set ESP8266 baud rate
  EspSerial.begin(ESP8266_BAUD); // Set ESP baud rate to 57600
  Blynk.begin(BLYNK_AUTH_TOKEN, wifi, ssid, pass);
  // Handle AT commands from Serial Monitor
  Serial.println("Ready to accept AT commands...");
  Blynk.run(); // Handle Blynk functions
  // Check if data is available from Serial Monitor (Arduino)
  if (Serial.available()) {
    // Read data from Serial Monitor
    String command = Serial.readString();
    // Send the command to ESP8266
    EspSerial.println(command);
  // Check if data is available from ESP8266 (AT commands response)
  if (EspSerial.available()) {
    // Read data from ESP8266 and send it to Serial Monitor (Arduino)
    String response = EspSerial.readString();
    Serial.print(response);  // Output the ESP response to Serial Monitor
First of all, read this link…
Secondly, if you’re using an Uno you need to comment-put this line…
Thirdly, what is all of this code for in the void loop?…
