Hello! Im using microcontroller on JavaScript, and i have a problem with connecting terminal widget.
Its my terminal in espruino web ide:
____ __
/ _/_____ / /__ _____ ____ _
/ / / ___// //_// ___// __ `/
_/ / (__ )/ ,< / / / /_/ /
/___//____//_/|_|/_/ \__,_/
Based on Espruino 1v85.1113
(c) 2016 G.Williams, Amperka LLC
Support the work of core developers:
Erasing Flash....
Writing................
Compressed 87200 bytes to 13546
Checking...
Done!
Loading 13546 bytes from flash...
Connecting to TCP: blynk-cloud.com 8442
Uncaught ReferenceError: "needsEmitter" is not defined
at line 1 col 1
needsEmitter()&&events.EventEmitter.call(this),this.pin=b,a....
in function "WidgetTerminal" called from line 34 col 38
var term = new blynk.WidgetTerminal(3);
=undefined
Connected
Disconnect blynk
Connected
Connected
Authorized
Here’s my code:
var BlynkLib = require('https://github.com/vshymanskyy/blynk-library-js/blob/master/blynk-espruino.js');
var blynk = new BlynkLib.Blynk('fb9386c0a3fd451d9740b53c707d7d52');
var v1 = new blynk.VirtualPin(1);
var v9 = new blynk.VirtualPin(9);
v1.on('write', function(param) {
console.log('V1:', param[0]);
v9.on('read', function() {
v9.write(new Date().getSeconds());
term.on('write', function(data) {
term.write('You wrote:' + data + '\n');
blynk.notify("HAHA! " + data);
How can i fix this problem?
