Rafli
November 4, 2022, 7:19am
1
Hello this is my code for my project
#define BLYNK_TEMPLATE_ID “-----”
#define BLYNK_DEVICE_NAME “-----”
#define BLYNK_AUTH_TOKEN “------”
//#define BLYNK_DEBUG
//#define APP_DEBUG
#include <EEPROM.h>
#include “GravityTDS.h”
#include <DHT.h>
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = “------”;
char pass[] = "----";
#define TdsSensorPin 14
#define EEPROM_SIZE 512
#define RELAY_PIN 27
#define DHT_SENSOR_PIN 32
#define DHT_SENSOR_TYPE DHT11
GravityTDS gravityTds;
DHT dht_sensor(DHT_SENSOR_PIN, DHT_SENSOR_TYPE);
float temperature = 25, tdsValue;
float a;
EEPROM.begin(EEPROM_SIZE);
gravityTds.setPin(TdsSensorPin);
gravityTds.setAref(3.3);
gravityTds.setAdcRange(4096);
gravityTds.begin();
dht_sensor.begin();
pinMode(TdsSensorPin,INPUT);
pinMode(25,OUTPUT);
digitalWrite(25, HIGH);
//temperature = readTemperature();
gravityTds.setTemperature(temperature);
gravityTds.update();
tdsValue = gravityTds.getTdsValue();
Serial.print("TDS Value:");
Serial.print(tdsValue,0);
Serial.println("ppm");
if(tdsValue < 500)
Serial.println("Low PPM, Pump Run");
digitalWrite(RELAY_PIN,HIGH);
delay(500);
else if (tdsValue>500&&tdsValue<600)
Serial.println("Enough PPM, Pump Dead");
digitalWrite(RELAY_PIN,LOW);
else if(tdsValue > 600)
float humid = dht_sensor.readHumidity();
float tempC = dht_sensor.readTemperature();
float tempF = dht_sensor.readTemperature(true);
Serial.print("Temp C:");
Serial.print(tempC);
Serial.print(",");
Serial.print("humid:");
Serial.print(humid);
Serial.print("\n");
Blynk.virtualWrite(V0, tempC);
Blynk.virtualWrite(V1, humid);
Blynk.virtualWrite(V14, tdsValue);
That’s my code, can someone tell me what’s wrong? because when I only use sensor code without Blynk code it can run and read sensor well.
Read what you posted
Your code is impossible to follow since you didn’t format your code correctly.
Keep your void loop() clean:
Firmware API, supported hardware, connection management, Blynk Mobile apps, tutorials, and more
@Rafli your unformatted code has been removed, because you didn’t follow the simple rules about adding triple backticks at the beginning and end.
Rafli
November 4, 2022, 8:07am
6
Yeah, thanks for the reminder I already fixed the wrong format.
First, clean your void loop, it would be like that
@Rafli “Need help with my project” is the correct category for this topic.
The “Issues and Errors” category is used for reporting bugs with the Blynk library, and this is a issue caused by coding errors on your part.
Rafli
November 4, 2022, 8:26am
9
So if I did that, then the old Void Loop will be in Void Setup?
No, the contents of your old void loop, minus the blocking delay(), will be in a function which is called with a timer.
I’d recommend calling that timer every 5 seconds or more, as the DHT sensors don’t respond well to higher frequency readings.
Also, it’s better to use BlynkTimer rather than SimpleTimer.
Many users seem to struggle with the basic concepts of using BlynkTimer in their projects, despite the excellent discussions and tutorials that exist on this forum, so I thought I’d write a guide that will hopefully help clarify things. It’s rather long, as it attempts to explain the reasoning behind why and how we use timers, and covers some more advanced subjects, but I’ve tried to organise it in a way that helps people to find answers to specific questions…
Why use a timer at all?
Let’s say …
Rafli
November 4, 2022, 11:46am
11
#include <EEPROM.h>
#include <DHT.h>
#include <WiFi.h>
float a;
void sendSensor()
if(tdsValue < 500)
delay(500);
Serial.print(",");
Serial.print("\n");
gravityTds.begin();
dht_sensor.begin(); \
Is it like this then?
Rafli:
delay(500);
Rafli:
Rafli:
Rafli:
I’m guessing that you aren’t a “detail person” then?
Rafli
November 4, 2022, 4:07pm
13
#include <EEPROM.h>
#include <DHT.h>
#include <WiFi.h>
float a;
void sendSensor()
if(tdsValue < 500)
Serial.print(",");
Serial.print("\n");
gravityTds.begin();
timer.setInterval(5000L, sendSensor);
I’ve done that, but the TDS sensor still cant read anything but when I delete the code Blynk.begin(auth, ssid, pass); and become offline then my sensor works again.
Rafli
November 4, 2022, 4:10pm
14
Is there could be some code that can be in the same void setup as Blynk.begin(auth, ssid, pass)?
These need to be the first lines of your sketch.
I’d also put these lines of code…
after #include <BlynkSimpleEsp32.h>
