Error uploading blynk edgent onto esp8266
#define BLYNK_TEMPLATE_ID "TMPLoIdpoJ_a"
#define BLYNK_TEMPLATE_NAME "Quickstart Template"
#define BLYNK_FIRMWARE_VERSION        "0.1.0"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
//#define USE_WEMOS_D1_MINI
#include "BlynkEdgent.h"
#include <Adafruit_AHTX0.h>
#include <wire.h>
Adafruit_AHTX0 aht;
Adafruit_Sensor *aht_humidity, *aht_temp;
// Declaring a global variabl for sensor data
//long temp;
//long humidity;
// This function creates the timer object. It's part of Blynk library. the timer has the code neccesarry to read the sensor data which is written
// to the blynk app when the timer function is called.
void myTimer()
  sensors_event_t humidity;
  sensors_event_t temp;
  aht_humidity->getEvent(&humidity); // gets the sensors humidity reading and stores it in the humidity variable.
  aht_temp->getEvent(&temp);// gets and stores temperature readings.
/**** display sensor readings on the serial monitor*/
  Serial.print("\t\tTemperature ");
  Serial.print(temp.temperature);
  Serial.println(" deg C");
  /* Display the results (humidity is measured in % relative humidity (% rH) */
  Serial.print("\t\tHumidity: ");
  Serial.print(humidity.relative_humidity);
  Serial.println(" % rH");
  Serial.print("\t\tTemperature: ");
  Serial.println(" degrees C");
  delay(100);
  // This function describes what will happen with each timer tick
  Blynk.virtualWrite(V0, temp.temperature); //writes the temperature to the bynk server
  Blynk.virtualWrite(V1, humidity.relative_humidity);//writes humidity to the bynk server virtual pin.
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
  Blynk.syncVirtual(V0);//**stores the previous temperature reading. this enables the device recall the last reading before it was turned off useful for switches*/
  Blynk.syncVirtual(V1);//stores the previous pressure reading
BlynkEdgent.begin();
  timer.setInterval(2000L,myTimer);
  //* AHT20 SETUP DETAILS***//
  Wire.begin(SDA0_Pin, SCL0_Pin);
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit AHT10/AHT20 test!");
  if (!aht.begin()) {
    Serial.println("Failed to find AHT10/AHT20 chip");
    while (1) {
  Serial.println("AHT10/AHT20 Found!");
  aht_temp = aht.getTemperatureSensor();
  aht_temp->printSensorDetails();
  aht_humidity = aht.getHumiditySensor();
  aht_humidity->printSensorDetails();
  //***end of AHT20 SENSOR SETUP****//
  BlynkEdgent.run();
after trying to upload this to my esp8266 I get this error message
C:\Users\HADAD\Documents\Arduino\Edgent_ESP8266_AHT20\BlynkEdgent.h:16:2: error: #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
   16 | #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
exit status 1
Compilation error: #error "Please specify your BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME"
i dont know what is the problem because I am able to upload ordinary bynk code on the esp. also the same code is runing well on my esp32 and I was able to upload it last week using arduino 2.3.2
The error message tells you exactly what the issue is, but you aren’t looking closely enough.
Read this…
Scenario 3 applies to you.
