Error sending push. Reason General OpenSslEngine problem
Hello dear After updating the local server for the latest version, the push notifications stopped working. Follow log:
12:23:16.854 INFO - Using data dir ‘/root/Blynk’
12:23:18.870 INFO - Region : local. Host : www.xxx.com.br.
12:23:19.043 INFO - Using native epoll transport.
12:23:20.016 INFO - Initializing gmail smtp mail transport. Username : reports@xxx.com.br. SMTP host : smtp.gmail.com:587
12:23:20.309 INFO - Reports : 0
12:23:20.318 INFO - Didn’t find Let’s Encrypt certificates.
12:23:20.318 INFO - Automatic certificate generation is turned ON.
12:23:20.318 INFO - Using native openSSL provider.
12:23:22.263 INFO - HTTP API and WebSockets server listening at 8080 port.
12:23:22.271 INFO - HTTPS API, WebSockets and Admin page server listening at 7443 port.
12:23:22.272 INFO - Mqtt hardware server listening at 8440 port.
12:23:24.997 INFO - daniel@xxx.com.br hardware joined.
12:24:15.300 INFO - Shared daniel@xxx.com.br app joined.
12:24:19.034 ERROR- Error sending push. Reason General OpenSslEngine problem
Just guessing here… but restart both the app and the server, just for good measure? go into the Phone app, remove the notify icon…logout - login and then re-add it?
Thanks for the tip. But I already did all this procedure and others. Unsuccessfully.
