Hello everyone, I have a problem with my project.
The program stops working completely when I put Blynk.begin (auth); on the void setup.
I’m new to the platform and I have this problem, could someone help me please?
#include <Keypad.h> //Libraries needed
#include <Wire.h>
#include <virtuabotixRTC.h>
#include <SerialRelay.h>
#include <OneWire.h>
#include <DHT.h>
#include <Ethernet.h>
#define DHTPIN 52 // Define em que pino está conectado o módulo DHT
#define DHTTYPE DHT22 // Define se o módulo conectado é o DHT11 ou DHT22
#define ONE_WIRE_BUS 53
OneWire oneWire(ONE_WIRE_BUS); //objeto one_wire
DeviceAddress sensor1;
DHT dht(DHTPIN, DHTTYPE);
const byte NumModules = 1;
SerialRelay relays(30,31,NumModules); // (data, clock, number of modules)
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
LiquidCrystal_I2C lcd(0x27, 20, 4);
LiquidCrystal_I2C lcd2(0x26, 16, 2);
virtuabotixRTC myRTC(32, 33, 34); //Wiring of the RTC (CLK,DAT,RST)
//If you change the wiring change the pins here also
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 4; //number of columns on the keypad
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[numRows] = {22,23,24,25}; //Rows 0 to 3 //if you modify your pins you should modify this too
byte colPins[numCols]= {26,27,28,29}; //Columns 0 to 3
int i1,i2,i3,i4;
char c1,c2,c3,c4;
char keypressed,keypressedx;
int A_hour=NULL;
int A_minute=NULL;
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
BlynkTimer timerDHT22; // Criação do Timer do DHT22
BlynkTimer timerDS18B20;
void lerSensorDHT22() // Função para ler os parâmetros do DHT22
float temperatura = dht.readTemperature(); // Comando da biblioteca que lê a temperatura adquirida pelo DHT22
float umidade = dht.readHumidity(); // Comando da biblioteca que lê a umidade adquirida pelo DHT22
if (isnan(temperatura) || isnan(umidade)) { // isnan = IS Not A Number <= verifica se o valor lido não é um número
return;
Blynk.virtualWrite(V4, temperatura); // Escreve no pino virtual V4 do Blynk o valor da temperatura lido pelo DHT22
Blynk.virtualWrite(V5, umidade); // Escreve no pino virtual V5 do Blynk o valor de umidade lido pelo DHT22
void lerSensorDS18B20()
float tempC = sensors.getTempCByIndex(0);
Blynk.virtualWrite(V2, tempC);
lcd.begin();
lcd2.begin();
lcd.backlight();
lcd2.backlight();
dht.begin(); // Inicializa o DHT22
Blynk.begin(auth);
timerDHT22.setInterval(2000L, lerSensorDHT22);
timerDS18B20.setInterval(1000L, lerSensorDS18B20);
while(keypressed == NO_KEY){ //As long as no key is pressed we keep showing the date and time, I'm obliged to clear the screen everytime so the numbers don't get confused
//And I should add that little delay so the screen shows correctly otherwise it didn't work for me
keypressed = myKeypad.getKey();
lcd.clear(); //Here after clearing the LCD we take the time from the module and print it on the screen with usual LCD functions
myRTC.updateTime();
if(myRTC.hours==A_hour && myRTC.minutes==A_minute && myRTC.seconds >= 0 && myRTC.seconds <= 2){
while(keypressedx == NO_KEY){
relays.SetRelay(1, SERIAL_RELAY_ON, 1);
delay(100);
lcd.clear();
lcd.print("Get up !!!"); //Message to show when the alarm is ringing
keypressedx = myKeypad.getKey();
keypressedx = NO_KEY;
lcd.setCursor(0,0);
lcd.print(myRTC.dayofmonth);
lcd.print("/");
lcd.print(myRTC.month);
lcd.print("/");
lcd.print(myRTC.year);
lcd.setCursor(12,0);
lcd.print(myRTC.hours);
lcd.print(":");
lcd.print(myRTC.minutes);
lcd.print(":");
lcd.print(myRTC.seconds);
delay(100);
float tempS = sensors.getTempCByIndex(0);
lcd.setCursor (0,1);
lcd.print("Temp Solo");
lcd.setCursor (0,2);
lcd.print(tempS);
lcd.print("C");
lcd2.setCursor(0,0);
lcd2.print("T-A:");
lcd2.print(temperatura);
lcd2.print("C");
lcd2.setCursor(0,1);
lcd2.print("U-A:");
lcd2.print(umidade);
lcd2.print("%");
delay(2000);
if (keypressed == '*')
lcd.clear();
lcd.print(" Setup");
lcd.clear();
lcd.print("Setup year");
char keypressed2 = myKeypad.waitForKey();
if (keypressed2 != NO_KEY && keypressed2 !='*' && keypressed2 !='#' && keypressed2 !='A' && keypressed2 !='B' && keypressed2 !='C' && keypressed2 !='D' )
c1 = keypressed2;
lcd.setCursor(0, 1);
lcd.print(c1);
char keypressed3 = myKeypad.waitForKey();
if (keypressed3 != NO_KEY && keypressed3 !='*' && keypressed3 !='#' && keypressed3 !='A' && keypressed3 !='B' && keypressed3 !='C' && keypressed3 !='D' )
c2 = keypressed3;
lcd.setCursor(1, 1);
lcd.print(c2);
char keypressed4 = myKeypad.waitForKey();
if (keypressed4 != NO_KEY && keypressed4 !='*' && keypressed4 !='#' && keypressed4 !='A' && keypressed4 !='B' && keypressed4 !='C' && keypressed4 !='D' )
c3 = keypressed4;
lcd.setCursor(2, 1);
lcd.print(c3);
char keypressed5 = myKeypad.waitForKey();
if (keypressed5 != NO_KEY && keypressed5 !='*' && keypressed5 !='#' && keypressed5 !='A' && keypressed5 !='B' && keypressed5 !='C' && keypressed5 !='D' )
c4 = keypressed5;
lcd.setCursor(3, 1);
lcd.print(c4);
i1=(c1-48)*1000; //the keys pressed are stored into chars I convert them to int then i did some multiplication to get the code as an int of xxxx
i2=(c2-48)*100;
i3=(c3-48)*10;
i4=c4-48;
int N_year=i1+i2+i3+i4;
delay(500);
lcd.clear();
lcd.print("Setup month");
char keypressed6 = myKeypad.waitForKey(); // here all programs are stopped until you enter the four digits then it gets compared to the code above
if (keypressed6 != NO_KEY && keypressed6 !='*' && keypressed6 !='#' && keypressed6 !='A' && keypressed6 !='B' && keypressed6 !='C' && keypressed6 !='D' )
c1 = keypressed6;
lcd.print(c1);
char keypressed7 = myKeypad.waitForKey();
if (keypressed7 != NO_KEY && keypressed7 !='*' && keypressed7 !='#' && keypressed7 !='A' && keypressed7 !='B' && keypressed7 !='C' && keypressed7 !='D' )
c2 = keypressed7;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
int N_month=i1+i2;
delay(500);
lcd.clear();
lcd.print("Setup Day");
char keypressed8 = myKeypad.waitForKey(); // here all programs are stopped until you enter the four digits then it gets compared to the code above
if (keypressed8 != NO_KEY && keypressed8 !='*' && keypressed8 !='#' && keypressed8 !='A' && keypressed8 !='B' && keypressed8 !='C' && keypressed8 !='D' )
c1 = keypressed8;
lcd.print(c1);
char keypressed9 = myKeypad.waitForKey();
if (keypressed9 != NO_KEY && keypressed9 !='*' && keypressed9 !='#' && keypressed9 !='A' && keypressed9 !='B' && keypressed9 !='C' && keypressed9 !='D' )
c2 = keypressed9;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
int N_day=i1+i2;
delay(500);
lcd.clear();
lcd.print("Setup hour");
char keypressed10 = myKeypad.waitForKey(); // here all programs are stopped until you enter the four digits then it gets compared to the code above
if (keypressed10 != NO_KEY && keypressed10 !='*' && keypressed10 !='#' && keypressed10 !='A' && keypressed10 !='B' && keypressed10 !='C' && keypressed10 !='D' )
c1 = keypressed10;
lcd.print(c1);
char keypressed11 = myKeypad.waitForKey();
if (keypressed11 != NO_KEY && keypressed11 !='*' && keypressed11 !='#' && keypressed11 !='A' && keypressed11 !='B' && keypressed11 !='C' && keypressed11 !='D' )
c2 = keypressed11;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
int N_hour=i1+i2;
delay(500);
lcd.clear();
lcd.print("Setup minutes");
char keypressed12 = myKeypad.waitForKey(); // here all programs are stopped until you enter the four digits then it gets compared to the code above
if (keypressed12 != NO_KEY && keypressed12 !='*' && keypressed12 !='#' && keypressed12 !='A' && keypressed12 !='B' && keypressed12 !='C' && keypressed12 !='D' )
c1 = keypressed12;
lcd.print(c1);
char keypressed13 = myKeypad.waitForKey();
if (keypressed13 != NO_KEY && keypressed13 !='*' && keypressed13 !='#' && keypressed13 !='A' && keypressed13 !='B' && keypressed13 !='C' && keypressed13 !='D' )
c2 = keypressed13;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
int N_minutes=i1+i2;
delay(500);
lcd.clear();
myRTC.setDS1302Time(22, N_minutes, N_hour, 1, N_day, N_month, N_year); //once we're done setting the date and time we transfer to values to the RTC module
//the 22 stands for seconds you can add a setup for it too if you want
//the 1 stands for day of the week, as long I don't show it on the screen I don't change it
keypressed=NO_KEY; //the "*" key is stored in "keypressed" so I remove that value from it otherwise it will get me in the setup again
/////////////////////////////////////////Alarme setup/////////////////////////////////
if (keypressed == 'A'){
lcd.clear();
lcd.print(" Config Alarme 1 ");
lcd.clear();
lcd.print("Hora");
char keypressed14 = myKeypad.waitForKey(); // here all programs are stopped until you enter the four digits then it gets compared to the code above
if (keypressed14 != NO_KEY && keypressed14 !='*' && keypressed14 !='#' && keypressed14 !='A' && keypressed14 !='B' && keypressed14 !='C' && keypressed14 !='D' )
c1 = keypressed14;
lcd.print(c1);
char keypressed15 = myKeypad.waitForKey();
if (keypressed15 != NO_KEY && keypressed15 !='*' && keypressed15 !='#' && keypressed15 !='A' && keypressed15 !='B' && keypressed15 !='C' && keypressed15 !='D' )
c2 = keypressed15;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
A_hour=i1+i2;
delay(500);
lcd.clear();
lcd.print("Minutos");
char keypressed16 = myKeypad.waitForKey(); // here all programs are stopped until you enter the four digits then it gets compared to the code above
if (keypressed16 != NO_KEY && keypressed16 !='*' && keypressed16 !='#' && keypressed16 !='A' && keypressed16 !='B' && keypressed16 !='C' && keypressed16 !='D' )
c1 = keypressed16;
lcd.print(c1);
char keypressed17 = myKeypad.waitForKey();
if (keypressed17 != NO_KEY && keypressed17 !='*' && keypressed17 !='#' && keypressed17 !='A' && keypressed17 !='B' && keypressed17 !='C' && keypressed17 !='D' )
c2 = keypressed17;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
A_minute=i1+i2;
delay(500);
lcd.clear();
keypressed=NO_KEY;
if (keypressed == 'D')
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Funcao: Alarme 1");
lcd.setCursor(0,1);
lcd.print("Desativada");
relays.SetRelay(1, SERIAL_RELAY_OFF, 1);
keypressed=NO_KEY;
delay(500);
else {
myRTC.updateTime();
keypressed=NO_KEY;
if (keypressed == 'B'){
lcd.clear();
lcd.print(" Config Alarme 2 ");
lcd.clear();
lcd.print("Hora");
c1 = keypressed14;
lcd.print(c1);
c2 = keypressed15;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
A_hour=i1+i2;
delay(500);
lcd.clear();
c1 = keypressed16;
lcd.print(c1);
c2 = keypressed17;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
A_minute=i1+i2;
delay(500);
lcd.clear();
keypressed=NO_KEY;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Funcao: Alarme 2");
lcd.setCursor(0,1);
keypressed=NO_KEY;
delay(500);
else {
myRTC.updateTime();
keypressed=NO_KEY;
if (keypressed == 'C'){
lcd.clear();
lcd.print(" Config Alarme 3 ");
lcd.clear();
lcd.print("Hora");
c1 = keypressed14;
lcd.print(c1);
c2 = keypressed15;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
A_hour=i1+i2;
delay(500);
lcd.clear();
c1 = keypressed16;
lcd.print(c1);
c2 = keypressed17;
lcd.print(c2);
i1=(c1-48)*10;
i2=c2-48;
A_minute=i1+i2;
delay(500);
lcd.clear();
keypressed=NO_KEY;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Funcao: Alarme 3");
lcd.setCursor(0,1);
keypressed=NO_KEY;
delay(500);
else {
myRTC.updateTime();
keypressed=NO_KEY;
timerDHT22.run(); // Inicializa o Timer do DHT22
timerDS18B20.run();
