Error Message Using Example 02_on_virtual_change.py
Here is the code I am using:
    import BlynkLib
    BLYNK_AUTH = 'my authorization code'
    # Initialize Blynk
    # Register virtual pin handler New Version
    @blynk.on("v3")
    def v3_write_handler(value):
         print('Current slider value: {}'.format(value
    while True:
        blynk.run()
The above example code from your latest website generates the following error:
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ for Python v0.2.6
Traceback (most recent call last):
File “02_on_virtual_change_Barry.py”, line 32, in
@blynk.on(“v3”)
AttributeError: ‘Blynk’ object has no attribute ‘on’
I am using a Raspberry Pi Zero. What am I doing wrong?
Thank you,
@Barry_Groden please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code.
Hi Pete,
I added the three backticks to the beginning and end of my program as requested.
Thanks,
Hi Pete,
Any suggestions regarding the problem I had posted?
Thank you,
I’m afraid not, I don’t use Python.
OK. Thank you. Maybe someone else has had this problem. Seems like a lot of people should have had it since it is so basic - the examples provided in the library do not appear to work. I have used other examples in prior versions of the library without any problems.
But, thanks again.
Regards,
