Even a first time post shouldn’t have blocked the addition of pasted code… and we didn’t see any system flags indicating such a block. ![]()
Anyhow, I have properly formatted your 2nd posts pasted code as required in the welcome topic and the initial post directions you needed to remove when posting your first text.
I also blocked out your AUTH code… you may still wish to refresh it in the App and in your code… prevents someone else from messing with your project.
This should be viewable in your IDE Board Manager…
Actually now up to 2.5.2
