Hello, I’m having troubles with this whenever I try to upload my code to esp8266 board. I have already tried all possible solutions I could see in the internet but it just displayed this error: error: failed reading byte
warning: espcomm_send_command: can’t receive slip payload data
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
I’m still new to coding. Hoping you could help me.
#include <Wire.h>
#include <DHT.h> // Including library for dht
#define DHTPIN 0 //pin where the dht11 is connected
DHT dht(DHTPIN, DHT11);
String apiKey = "0LG1OTPGODSQFWLV"; // Enter your Write API key from ThingSpeak
const char *ssid = "zbaguio"; // replace with your wifi ssid and wpa2 key
const char *pass = "zarinatwins";
const char *server = "api.thingspeak.com";
const int AirValue = 790; //you need to replace this value with Value_1
const int WaterValue = 390; //you need to replace this value with Value_2
const int SensorPin = A0;
int soilMoistureValue = 0;
int soilmoisturepercent= 0;
int relaypin = 16;
WiFiClient client;
Serial.begin(115200); // open serial port, set the baud rate to 9600 bps
pinMode(relaypin, OUTPUT);
dht.begin();
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
Serial.println("");
delay(4000);
float h = dht.readHumidity();
Serial.print("Humidity: ");
Serial.println(h);
Serial.println(t);
soilMoistureValue = analogRead(SensorPin); //put Sensor insert into soil
Serial.println(soilMoistureValue);
soilmoisturepercent = map(soilMoistureValue, AirValue, WaterValue, 0, 100);
if(soilmoisturepercent >=0 && soilmoisturepercent <= 30)
digitalWrite(relaypin, HIGH);
Serial.println("Motor is ON");
else if (soilmoisturepercent >30 && soilmoisturepercent <= 100)
digitalWrite(relaypin, LOW);
Serial.println("Motor is OFF");
if (client.connect(server, 80)) // "184.106.153.149" or api.thingspeak.com
String postStr = apiKey;
postStr += "&field1=";
postStr += String(soilmoisturepercent);
postStr += "&field2=";
postStr += String(h);
postStr += "&field3=";
postStr += String(t);
postStr += "&field4=";
postStr += String(relaypin);
postStr += "\r\n\r\n\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
client.stop();
```cpp
