@Hayk Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your compiler error message and your code so that they display correctly.
In file included from c:\Users\User\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14, from c:\Users\User\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:20, from C:\Users\User\Desktop\New sketch\sketch_jul31a\sketch_jul31a.ino:3: c:\Users\User\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:39:6: error: #error “Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME” #error “Please specify your BLYNK_TEMPLATE_ID and BLYNK_TEMPLATE_NAME” ^~~~~ exit status 1 Compilation error: exit status 1
This was the error in the first post. This is a “bug” in lib 1.3 so in arduino you can’t compile
There is a change in library version 1.3.0 which no longer tolerates the use of BLYNK_DEVICE_NAME and now requires the new BLYNK_TEMPLATE_NAME to be used. Version 1.2.0 tolerated either.
more info here…
However, this doesn’t appear to be @Hayk’s problem, and once he edits his post to add triple backticks I’ll engage with him to help identify and resolve the issue - which I suspect is a missing quotation mark.
If you’re having a similar issue then I’d suggest taking a close look at your code, and if you can’t fix the issue then start a new topic and post your code and compiler error message (both correctly formatted) and any other relevant information.
спосиба я вас очень блогадарень. но я не поняль что надо изменить в этих строках и я просто изменил библятеку на 1.2.0 .
можите вы показать премер буду очень блогадарень
