I recently purchased a nodemcu esp8266 wifi module and tried it with an example program below. I successfully compiled it at first and be able to execute it with the help of blynk app. But i accidentally deleted my blynk library. And when i installed it, the error starts to occur. This is the program…
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
char pass[] = "YourPassword";
And here is the error message…
he error that always been happening. Hope you van help me.TIA
Arduino: 1.8.13 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from C:\Users\Luwee\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:37,
from C:\Users\Luwee\Documents\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
from C:\Users\Luwee\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp8266.h:24,
from C:\Users\Luwee\Desktop\OJT\New folder\NodeMCU_Program1\NodeMCU_Program1.ino:4:
C:\Users\Luwee\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: error: redefinition of 'class BlynkTimer'
36 | #define SimpleTimer BlynkTimer
C:\Users\Luwee\Documents\Arduino\libraries\SimpleTimer/SimpleTimer.h:10:7: note: in expansion of macro 'SimpleTimer'
10 | class SimpleTimer {
C:\Users\Luwee\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: note: previous definition of 'class BlynkTimer'
C:\Users\Luwee\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:41:7: note: in expansion of macro 'SimpleTimer'
41 | class SimpleTimer {
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
option enabled in File -> Preferences.```
Hope you can help me. TIA
