#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
#define BLYNK_FIRMWARE_VERSION "0.1.2"
#include <BlynkSimpleEsp32.h>
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
#include "BlynkEdgent.h"
bool alarm_mode = false ;
int sensor = 5;
void myTimerEvent(){
if(digitalRead(sensor) == 0){
Blynk.virtualWrite(V2, "CLOSE");
if(digitalRead(sensor) == 1){
Blynk.virtualWrite(V2, "OPEN");
BLYNK_WRITE(V0)
if ( param.asInt () == 1)
digitalWrite(23,LOW);
digitalWrite(23,HIGH);
BLYNK_WRITE(V1)
digitalWrite(22,LOW);
digitalWrite(22,HIGH);
BLYNK_CONNECTED()
Blynk.syncVirtual(V0);
Blynk.syncVirtual(V1);
delay(100);
pinMode(sensor, INPUT_PULLUP);
pinMode(23,OUTPUT);
pinMode(22,OUTPUT);
BlynkEdgent.begin();
BlynkEdgent.run();
Dear Blynk team i have this error
In file included from sketch\BlynkEdgent.h:9:0,
from C:\Users\hosaifa\Documents\Arduino\Edgent_ESP32_new\Edgent_ESP32_2relay\Edgent_ESP32_2relay.ino:17:
C:\Users\hosaifa\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h:54:7: error: 'BlynkWifi' is not a template type
class BlynkWifi
C:\Users\hosaifa\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h:128:25: error: conflicting declaration 'WiFiClientSecure _blynkWifiClient'
static WiFiClientSecure _blynkWifiClient;
In file included from C:\Users\hosaifa\Documents\Arduino\Edgent_ESP32_new\Edgent_ESP32_2relay\Edgent_ESP32_2relay.ino:7:0:
C:\Users\hosaifa\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:93:19: note: previous declaration as 'WiFiClient _blynkWifiClient'
static WiFiClient _blynkWifiClient;
C:\Users\hosaifa\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h:129:83: error: conflicting declaration 'BlynkArduinoClientSecure<WiFiClientSecure> _blynkTransport'
static BlynkArduinoClientSecure<WiFiClientSecure> _blynkTransport(_blynkWifiClient);
C:\Users\hosaifa\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:94:27: note: previous declaration as 'BlynkArduinoClient _blynkTransport'
static BlynkArduinoClient _blynkTransport(_blynkWifiClient);
C:\Users\hosaifa\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h:130:1: error: 'BlynkWifi' is not a template
BlynkWifi<BlynkArduinoClientSecure<WiFiClientSecure> > Blynk(_blynkTransport);
C:\Users\hosaifa\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32_SSL.h:130:77: error: redefinition of 'BlynkWifi Blynk'
C:\Users\hosaifa\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:95:11: note: 'BlynkWifi Blynk' previously declared here
BlynkWifi Blynk(_blynkTransport);
Multiple libraries were found for "BlynkSimpleEsp32.h"
Used: C:\Users\hosaifa\Documents\Arduino\libraries\Blynk
Not used: C:\Program Files (x86)\Arduino\libraries\Blynk
Not used: C:\Users\hosaifa\Documents\Arduino\libraries\blynk-library-master
Multiple libraries were found for "WiFi.h"
Used: C:\Users\hosaifa\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
Error compiling for board ESP32 Wrover Module.```
@Huzefamaz1 please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Please also use triple backticks around your compiler error message in your second post.
If you can’t find the backtick symbol on your keyboard please copy/paste the ones I’ve provided above.
Dear sir
thanks for your prompt reply yes i will did
If you’re using a WROVER board, then un-commenting #define USE_WROVER_BOARD would be a good start…
What version of the Blynk library do you have installed?
Dear sie thanks for reply
this i allready Define sir still same issue Sir i am using this verson sir 1.0.1
Try deleting all of the Blynk libraries (using file manager) and re-installing using the IDE.
Dear sir
thanks for reply ok i will do now sir
Dear sir
yes i did still same issue sir “Error compiling for board ESP32 Wrover Module.” showing this
from C:\Users\hosaifa\Documents\Arduino\compaling_eror\compaling_eror.ino:16:
class BlynkWifi
In file included from C:\Users\hosaifa\Documents\Arduino\compaling_eror\compaling_eror.ino:7:0:
exit status 1
What happens if you open the latest Edgent ESP32 example, add-in your template details and try compiling that?
Dear sir thanks for Replying
Yes sir I will try that as well Still showing same ERROR sir this issue is since from last week still I can’t settle please help me
I have no idea what this means.
Dear sir
When I use BLYNK.egent then only have this issue sir I use normal Blynk (legency) no issue sir
Thanks for replying this issues setlle allready thank you I have now another issue I attached the screen shot here please reply that thanks you
Best Regards
Maaz
You already have a post in the forum about this issue, so I’m closing this topic.
