Hi.
I would’l to ask - if I make local server - energy in app will be still limited? If I buy some energy - it will be able to use in all projects (for example 5000 to spend in every project or limited to 5000 in all of them) ?
Hi.
How did you configure that much energy - I assume some confiig setting ? Can you explain
Use the webinterface Admin part of the local server. There you can configure your energy
