I have an Arduino Uno, an Esp8266 and a LED-Strip (WS2812) and try to implement functions by pressing a button. The functions work fine, but I´m not able to read out a new pin value from my virtual pin in my while-loops of my functions to end the function. I always have to shut down my esp8266 to control my LED-strip again. Can someone give me the solution for this? Thanks in advance!!
int valueV6;
int data = 50;
BLYNK_WRITE(V6) // Here is one of my functions, which read out virtual pin V6
valueV6 = param.asInt();
if(valueV6 == 1)
static1(0,0,0,0); //static1 is a function which sets static values to my LED-strip(it is shut off here)
delay(30);
effect3();
else{
static1(r,g,b,data);
void effect3()
int n = 0;
int m = 0;
while(valueV6 == 1)
for (int i = 0; i < 256; i++)
leds1[n] = CRGB(50,50,50);
FastLED.setBrightness(i);
delay(1);
FastLED.show();
for (int i = 256; i > 0; i--)
delay(1);
FastLED.show();
FastLED.clear(); // around here I would like to read out the virtual pin V6 again, to eventually
n++; // end the while loop, if the button is set to 1/LOW
if (n == 60) // valueV6 = param.asInt(); does unfortunately not work!
n = 0;
void static1(int r, int g, int b,int brightness)
for (int i = 0; i < NUM_LEDS1; i++ )
leds1[i] = CRGB(r, g, b);
if(pinValue == HIGH){
FastLED.setBrightness(brightness);
else{
FastLED.setBrightness(0);
FastLED.show();
