I can’t compile the example included in the blynk library. I get the following error:
In file included from \Documents\Arduino\libraries\blynk-library-master/BlynkSimpleUIPEthernet.h:15:0,
from ENC28J60.ino:29:
\Documents\Arduino\libraries\blynk-library-master/Adapters/BlynkEthernet.h:21:22: fatal error: Ethernet.h: No such file or directory
#include <Ethernet.h>
compilation terminated.
Error compiling.
Is there anything I did wrong when installing Blynk?
@mba2007,
This example is specially for ENC28J60 module.
Please see the comment on the top of this sketch, which says:
This example shows how to use ENC28J60 (UIPEthernet library)
to connect your project to Blynk.
For this example you need UIPEthernet library:
https://github.com/ntruchsess/arduino_uip
If you have connected your Arduino to the ENC28J60, go ahead downloading the specified library
Also, take a look at our Troubleshooting page.
Hope this helps.
Thanks for the quick reply! I did download UIPEthernet (it shows up in Sketch>Include Library). But the example still doesn’t compile.
@mba2007,
Sorry I now see that we have this problem. We will fix it in next library update.
For now, I checked that you can use this example with Arduino IDE v1.0.6 (it works well there).
Sorry for inconvenience.
@mba2007, the issue was fixed.
You can try using the latest version (master) from git:
https://github.com/blynkkk/blynk-library/archive/master.zip
Note that it may be unstable (it was not released yet).
