Is it possible to use a string variable instead of a text between quote? I tried it but it does not work.
String emailmessage;
emailmessage="This is a test";
Blynk.email("test@gmail.com", "Blynk", emailmessage);
@michel.richir I was pretty sure String was ok but you could:
char emailmessage[];
If this fails I can check some of my projects or you have a bug in your sketch that prevents the email being sent.
Convert to String like below
Blynk.email("test@gmail.com", "Blynk", String(emailmessage));
Strangely enough, I tested again my original code changing the email address to a non gmail account. It works.
Not necessary to redeclare “emailmessage” as a string…
Hi, how would I add a Carriage Return and Line Feed in die String(emailmessage)?
You can use html formatting:
I use the following:
emailmessage = “this is line 1
emailmessage = emailmessage + “this is line 2
Blynk.email(emailto, subject, emailmessage);
Hi Michel,
Thanx for the info. Just try it but is missing something…
When I use the following code:
emailBody = “first line.”;
emailBody = emailBody + “second line…”;
Blynk.email(String(emailSubject), String(emailBody));
The string gets printed on one line within the message.
When I use the following:
emailBody = "first line.
Blynk.email(emailSubject, emailBody);
I’m getting a compile error “missing terminating " character” …
Even trying something like this don’t work…
emailBody = emailBody + “\n” + “\r”;
Any other suggestions?
Email is HTML so if you what to break the line you need to use <p>
