Eeprom issue, can I just change where the version is stored?
OK, I think I’ve diagnosed an odd issue in my code, but I’m not familiar with eeprom enough to just wing it here.
In short, I have a light sensor that stores something at 0x00, but Blynk config also stores version history there.
Can I just change the blynk config to another block… any blocks I can’t use aside those that are already used in my project?
Thank you!
  • Nick
Code snippets below:
Light Sensor config:
#define TLS2561_REGISTER_CONTROL 0x00
Blynk Config:
const ConfigStore configDefault = {
  0x626C6E6B,
  BLYNK_FIRMWARE_VERSION,
  0x00,
I’d change where you store your data rather than messing with the configstore.
You should read this…
Thanks Pete! That seems like a solution to my issue too.
Not an expert coder, but this looks straightforward.
