Hi all.
Please tell me how to disable sticking PIN - 0, when turned on after Edgent firmware ???
Hi all.
Hardware?
Blynk library version?
What does “sticking” mean.
Which board type have you un-commented in your sketch?
Everything is standard.
The sketch is standard.
Board - esp8266
sticking - means. When the board is rebooted, pin - 0. is on! And I need to be off. How to make the pin - 0, was in the OFF state.
And the answers to the rest of my questions?
Hardware? - iOS 14.6 / blynk 2.0 / OS Zorin 15.3 bionic./ Arduino 1.8.12
Blynk library version - Volodymyr Shymanskyy 1.0.1
Sketch standart “Edagent” simple:
#define BLYNK_TEMPLATE_ID "T*******6b"
#define BLYNK_DEVICE_NAME "lol"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
//#define USE_WEMOS_D1_MINI
#include "BlynkEdgent.h"
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
settings.h
* Board configuration (see examples below).
#if defined(USE_NODE_MCU_BOARD) || defined(USE_WEMOS_D1_MINI)
#define BOARD_BUTTON_PIN 1
#define BOARD_BUTTON_ACTIVE_LOW false
#define BOARD_LED_PIN 2
#define BOARD_LED_INVERSE false
#define BOARD_LED_BRIGHTNESS 255
#elif defined(USE_SPARKFUN_BLYNK_BOARD)
#define BOARD_LED_PIN_WS2812 4
#define BOARD_LED_BRIGHTNESS 64
#elif defined(USE_WITTY_CLOUD_BOARD)
#define BOARD_BUTTON_PIN 4
#define BOARD_LED_PIN_R 15
#define BOARD_LED_PIN_G 12
#define BOARD_LED_PIN_B 13
#else
#warning "Custom board configuration is used"
#define BOARD_BUTTON_PIN 1 // Pin where user button is attached
#define BOARD_BUTTON_ACTIVE_LOW false // true if button is "active-low"
#define BOARD_LED_PIN 4 // Set LED pin - if you have a single-color LED attached
//#define BOARD_LED_PIN_R 15 // Set R,G,B pins - if your LED is PWM RGB
//#define BOARD_LED_PIN_G 12
//#define BOARD_LED_PIN_B 13
//#define BOARD_LED_PIN_WS2812 4 // Set if your LED is WS2812 RGB
#define BOARD_LED_INVERSE false // true if LED is common anode, false if common cathode
#define BOARD_LED_BRIGHTNESS 64 // 0..255 brightness control
#endif
* Advanced options
#define BUTTON_HOLD_TIME_INDICATION 3000
#define BUTTON_HOLD_TIME_ACTION 10000
#define BOARD_PWM_MAX 1023
#define CONFIG_AP_URL "blynk.setup"
#define CONFIG_DEFAULT_SERVER "blynk.cloud"
#define CONFIG_DEFAULT_PORT 443
#define WIFI_NET_CONNECT_TIMEOUT 30000
#define WIFI_CLOUD_CONNECT_TIMEOUT 60000
#define WIFI_AP_IP IPAddress(192, 168, 4, 1)
#define WIFI_AP_Subnet IPAddress(255, 255, 255, 0)
//#define WIFI_CAPTIVE_PORTAL_ENABLE
#define USE_TICKER
//#define USE_TIMER_ONE
//#define USE_TIMER_THREE
//#define USE_TIMER_FIVE
//#define USE_PTHREAD
#define BLYNK_NO_DEFAULT_BANNER
#if defined(APP_DEBUG)
#define DEBUG_PRINT(...) BLYNK_LOG1(VA_ARGS)
#else
#endif
I tried to change something in the settings.h, unsuccessfully …
Have you tried adding a pinMode and digitalWrite command for GPIO0 in your void setup?
Yes, now I’ll show you exactly how I did it … just a minute.
#define BLYNK_TEMPLATE_ID "*****P6b"
#define APP_DEBUG
int zerooffplease = 0;
delay(100);
pinMode(zerooffplease, INPUT);
digitalWrite(zerooffplease, LOW);
BlynkEdgent.run();
It did not help, when flashing and rebooting the board, pin 0, in the ON position.
How can you write to an INPUT ?
The only way to pull an input LOW is via a physical pull-down resistor.
If you wanted to pull an input HIGH then you can use INPUT_PULLUP in your pinMode statement, but there is no corresponding INPUT_PULLDOWN command for the ESP8266.
I want pin - 0 to be turned off at board start, by default.
If anyone needs to fix the pin 0 enabled problem, I solved it like this:
#define APP_DEBUG
int PIN = 0;
delay(100);
BlynkEdgent.run();
pinMode(PIN, OUTPUT);
A word of advice to anyone reading this - don’t put a pinMode statement in your void loop!
Well, or describe your version.
Those who read. Sure.
pinMode statements only need to be executed once, so they normally appear in void setup()
, or in a function which is called only once.
The problem that you have is that by un-commenting this line:
your code uses this board configuration in Settings.h
#define BOARD_BUTTON_PIN 0
#define BOARD_BUTTON_ACTIVE_LOW true
#define BOARD_LED_INVERSE true
This assigns GPIO0 to the BOARD_BUTTON_PIN
variable, and true
to the BOARD_BUTTON_ACTIVE_LOW
variable.
in ResetButton.h, because BOARD_BUTTON_ACTIVE_LOW
== true
, GPIO0 is initialised as an input, with the INPUT_PULLUP
modifier:
void button_init()
#if BOARD_BUTTON_ACTIVE_LOW
pinMode(BOARD_BUTTON_PIN, INPUT_PULLUP);
#else
pinMode(BOARD_BUTTON_PIN, INPUT);
#endif
attachInterrupt(BOARD_BUTTON_PIN, button_change, CHANGE);
If you re-declare GPIO0 as an OUTPUT then the on-board FLASH button (which is connected to GPIO0) can’t be used to clear the WiFi credentials and force re-provisioning of the board.
Thanks for your answer, Pete.
I will carefully study your recommendations and try to come to the right decision.
