Hi. I just updated my esp32 board in arduino and now in the console.h file in the Edgent_ESP32 example I get this error. I’m including the console.h code for quick reference. How can I fix this. The error is:
In file included from /home/pi/Arduino/Edgent_ESP32/BlynkEdgent.h:25,
from /home/pi/Arduino/Edgent_ESP32/Edgent_ESP32.ino:19:
/home/pi/Arduino/Edgent_ESP32/Console.h: In lambda function:
/home/pi/Arduino/Edgent_ESP32/Console.h:30:9: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
/home/pi/Arduino/Edgent_ESP32/Console.h:45:9: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
I don’t know what to tell you except it isn’t working. Edgent wasn’t working with my esp32 so I updated Arduino and the Blynk library and now I get this. I’m not liking Blynk right now.
Sorry. I know that it doesn’t work, means nothing. What would cause edgent to get through all of the steps of finding and connecting the WiFi, connecting to the server, but stopping at “Waiting for device online”?
I’m not familiar with the board you are using.
I’d suggest that you look at the board types in the Settings.h file and see if there are any settings that conflict with your board, for whatever board type you’ve un-commented in the .ino file (or for the default settings if you haven’t un-commented a board type).
Did you already try without Edgent to see if device gets connected? For that load “normal” esp32 example file and put the 2 device id and template name lines from the web console at the top of the code.
Also fill in your ssid and password for WiFi.
Actually, I did use a normal sketch, but not with the new Blynk app. So far, I just got the legacy app to work, but I really wanted to have the web dashboard, so I decided to try to migrate the project to the new app
That’s fine, I can try that, but I’m sending this device to my partner for demonstration and I have no idea what the WiFi credentials will be where he is doing the demo. How do I set it up to be able to access other wifi networks? Also, what would cause the new app.to get all the way to “waiting for device online” and time out there?
If it’s a corporate or educational network then the Blynk data packets may be blocked anyway.
One option could be to use a hotspot on a phone, where you specify the SSID and password, but once again, some mobile ISPs block Blynk data in this scenario.
Assuming that the data isn’t blocked then you could use WiFiManager.
I have no idea, but the starting point is to ensure that your device can connect with a non-Edgent sketch.
You should probably provide information about the app operating system and version, and send do About —> Send Logs to send the mobile device logs to the developer.
