Easy Blynk Programming
Blynk is very good platform to work in IOT. I have a Idea for Improving simplicity of software Programming. I have connected 2 channel Relay to the arduino and it worked properly, Now if I have to connect Bluetooth to it, have to change program.
I wish if there is feature available where I will keep my relay program same and for connecting blutetooth, the additonal program just to add over it,
For Example-
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
digitalWrite(8,HIGH);
digitalWrite(9,LOW);
delay (5000);
digitalWrite(8,LOW);
digitalWrite(9,HIGH);
delay (5000);
/*with bluetooth*/
Void Bluetooth()
{ Virtual Pin 8 = Digital Pin 8
Virtual Pin 9 = Digital Pin 9
Serial band width = 9600
/*and other essential things important to the additional program*/
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
delay (5000);
delay (5000);
/*Same For WIFI
Instead of bluetooth we should only replace word Wifi
and other program remains same*/
Void WIFI()
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
delay (5000);
delay (5000);
@sf2020 please edit your post (using the pencil icon at the bottom) and add triple backticks at the beginning and end of each of your two sections of code so that the code displays correctly.
Edited
What is your question? :thinking:
Nice!
There’s nothing about blynk :scream:
