"DSR is off" problem
Hi, I’m JB who started to use blynk for 4month, usually, I worked with cloud server. But, today I made my own server on windows and try to use blynk with arduino uno with usb serial before my nodeMCU comes, I did everything same as what I did with cloud server and did
’ C:\Users\북 4>cd C:\Users\북 4\Documents\Arduino\libraries\Blynk\scripts
C:\Users\북 4\Documents\Arduino\libraries\Blynk\scripts>blynk-ser.bat -c COM4 -b9600 -s 192.168.35.241 -p 9443’
did this on CMD… but It keeps saying that DSR is off… tried some other things on Blynk comunity but didn’t work…
Hope anyone of you can help me :smiley:!
and Here is my code :
char auth[] = "c33e7c58836e4a9da6965f75759d5b7e";
  DebugSerial.begin(9600);
  Blynk.begin(Serial, auth);
I think from memory that’s the response you want and you should be good to go. Remember to keep the command window open though.
A post was merged into an existing topic: Issues using USB link - DSR is off - project is offline
That is fine… it is NOT an error.
Unless you are specifically trying to run an SSL library… use port 8080
