Hello.
What is wrong?
I am trying to connect the display to BLYNK
Error:
C:\Users\xxx\Desktop\sketch_feb11a\sketch_feb11a.ino: In function ‘void temperatura()’:
sketch_feb11a:115: error: ‘getTemp’ was not declared in this scope
float temperature = getTemp();
exit status 1
#include <OneWire.h>
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7);
#define BACKLIGHT_PIN 3
#define ONE_WIRE_BUS 2 // This is the ESP8266 pin
DeviceAddress tempSensor1 = { 0x28, 0xFF, 0xD5, 0x1B, 0x80, 0x16, 0x05, 0x73 }; // Adres temperatury #1
DeviceAddress tempSensor2 = { 0x28, 0xFF, 0x72, 0x55, 0x80, 0x16, 0x05, 0xE4 }; // Adres temperatury #2
char auth[] = "xxxx"; // Kod BLYNK
char ssid[] = "xxxx"; // Login WIFI
char pass[] = ""; // Hasło WIFI
int pin = D2; // Pin cyfrowy krancówka
WidgetLED led1(V3); // Pin wirtualny krancowy
int pin2 = D3; // Pin cyfrowy krancówka
WidgetLED led2(V4); // Pin wirtualny krancowy
int pin3 = D4; // Pin cyfrowy krancówka
WidgetLED led3(V5); // Pin wirtualny krancowy
int tempC1, tempC2; // Variables for storing temperatures
BLYNK_CONNECTED() {
Blynk.syncAll();
// Wait until connected
lcd.begin (16,2);
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
lcd.setCursor(0, 0);
lcd.print("Temp:");
lcd.setCursor(11, 0);
lcd.print(" ");
lcd.write(0xDF); // Znak stopnia
lcd.print("C ");
sensors.begin();
timer.setInterval(1000L, brama1); //Sprawdzanie stanu
timer.setInterval(1000L, brama2); //Sprawdzanie stanu
timer.setInterval(1000L, brama3); //Sprawdzanie stanu
sensors.setResolution(tempSensor1, 9); // More on resolutions: http://www.homautomation.org/2015/11/17/ds18b20-how-to-change-resolution-9101112-bits/
sensors.setResolution(tempSensor2, 9);
// These timers are used so that data does not flood Blynk
timer.setInterval(5000L, sendSensor1); // Czas pomiaru temperatury #1
timer.setInterval(5000L, sendSensor2); // Czas pomiaru temperatury #2
void sendSensor1() {
sensors.requestTemperatures(); // Polls the sensors
tempC1 = sensors.getTempC(tempSensor1); // C - celsjusza / F - fahrenheita
Blynk.virtualWrite(1, tempC1); // 1 Pin wirtualny
void sendSensor2()
tempC2 = sensors.getTempC(tempSensor2);
Blynk.virtualWrite(2, tempC2); // 2 Pin wirtualny
void brama1()
if(digitalRead(pin) == 1){
led1.on();
else{
led1.off();
void brama2()
if(digitalRead(pin2) == 1){
led2.on();
else{
led2.off();
void brama3()
if(digitalRead(pin3) == 1){
led3.on();
else{
led3.off();
void temperatura()
Serial.println(temperature);
lcd.setCursor(6, 0);
lcd.print(temperature);
delay(1000); //just here to slow down the output so it is easier to read
