Seems to be a lot of people having success with Blynk and ESP’s, not sure why I am having this problem, but here it is.
I made a fairly basic DHT22 based temp/humidity sensor on an ESP8266 dev board, with a SSD1306 OLEAD display, a couple of simple buttons wired to GPIO pins and a battery level sensor to the analog pin. That all went pretty well, so then I added some simple Blynk code to get the thing logging to the cloud and got immediate problems.
It was connecting fine but then immediately crashing, resetting and reconnecting… A whole lot of this:
[3079] Con2:AndroidAP
[7312] Conn2WiFi
[7312] IP=192.168.1.89,GW=192.168.1.1,SN=255.255.255.0
[7312] DNS1=192.168.1.1,DNS2=(IP unset)
[7313]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.1 on ESP8266_GENERIC
[8463] NTP time: Sun Feb 13 08:25:02 2022
[8679] Connecting to blynk.cloud:443
[9936] Certificate OK
[9937] <[1D|00|01|00] xPUKc5khUcZ10-e5nO_kvt5x4NEVJsrd
[10054] >[00|00|01|00|C8]
[10054] Ready (ping: 1ms).
[10055] Free RAM: 16344
[10121] <[11|00|02|00]vver[00]1.0.1[00]h-beat[00]45[00]buff-in[00]256[00]dev[00]ESP8266_GENERIC[00]fw-type[00]TMPLPTJB5J6u[00]build[00]Feb 13 2022 18:23:21[00]tmpl[00]TMPLPTJB5J6u[00]
[13317] >[00|00|02|00|C8]
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Exception (28):
epc1=0x4020509e epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000010 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffdd0 end: 3fffffc0 offset: 0190
3fffff60: 00000000 00000000 00000000 3ffef0bc
3fffff70: 00004650 00001d26 3ffef884 3ffefe20
3fffff80: 3fffdad0 3ffefcd0 3ffef884 402058f5
3fffff90: 3fffdad0 00000000 3ffefe0c 40205247
3fffffa0: feefeffe 00000000 3ffefe0c 4020d29c
3fffffb0: feefeffe feefeffe 3ffe86dc 40100f61
<<<stack<<<
⸮[3078] Con2:AndroidAP
I searched for similar problems, heard something about issues with sprintf causing issues, wrote a replacement for that, no joy.
So then I tried an ESP32-WROOM and got the same thing; connecting then crash (“Guru Meditation Error: Core 1 panic’ed (LoadProhibited). Exception was unhandled.”) and reboot.
Then I stripped the code completely bare to just this:
#define BLYNK_TEMPLATE_ID "zzzzzzzzzzzzzzzzzzzzzz"
#define BLYNK_DEVICE_NAME "zzzzzzzzzzz "
#define BLYNK_AUTH_TOKEN "zzzzzzzzzzzzzzzzzzzzz"
#define BLYNK_DEBUG
#include <BlynkSimpleEsp32_SSL_WM.h>
char auth_token[] = BLYNK_AUTH_TOKEN;
char wifi_ssid[] = "AndroidAP";
char wifi_pass[] = "password123";
Blynk.begin(auth_token, wifi_ssid, wifi_pass);
void loop(){
Same result.
So then I got out another brand new ESP32 dev board straight out of the anti-static bag and got the same result.
Con2:AndroidAP
[2638] Conn2WiFi
[2638] IP=192.168.1.226,GW=192.168.1.1,SN=255.255.255.0
[2638] DNS1=192.168.1.1,DNS2=0.0.0.0
[2638]
___ __ __
/___/ v1.0.1 on ESP32_DEV
[2781] NTP time: Sun Feb 13 05:43:06 2022
[2825] Connecting to blynk.cloud:443
[4435] Certificate OK
[4435] <[1D|00|01|00] ohuYoxPJXexEKwdXxlh5WlPHCTn5E7cG
[4737] >[00|00|01|00|C8]
[4738] Ready (ping: 301ms).
[4805] <[11|00|02|00]pver[00]1.0.1[00]h-beat[00]45[00]buff-in[00]256[00]dev[00]ESP32_DEV[00]fw-type[00]TMPLkuO0T-LF[00]build[00]Feb 13 2022 15:42:26[00]tmpl[00]TMPLkuO0T-LF[00]
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400d2105 PS : 0x00060a30 A0 : 0x800d2269 A1 : 0x3ffb1f70
A2 : 0x3ffc1724 A3 : 0x00000000 A4 : 0x00000adb A5 : 0x00000061
A6 : 0x3ffc1b70 A7 : 0x00000000 A8 : 0x00000000 A9 : 0x00000001
A10 : 0x00000001 A11 : 0x00000000 A12 : 0x3ffc1724 A13 : 0x00000079
A14 : 0x00000000 A15 : 0x3ffc658c SAR : 0x0000000a EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000010 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
ELF file SHA256: 0000000000000000
Backtrace: 0x400d2105:0x3ffb1f70 0x400d2266:0x3ffb1f90 0x400d6274:0x3ffb1fb0 0x40089872:0x3ffb1fd0
Rebooting...
Along the way I completely removed and reinstalled my entire Arduino IDE installation and all libraries twice.
Eventually after working out which way round to read the ESP Exception Decoder (backtrace heh) I ended up here:
0x400d23bd: DoubleResetDetector::loop() at C:\Users\User\Documents\Arduino\libraries\ESP_DoubleResetDetector\src/ESP_DoubleResetDetector.h line 210
: (inlined by) BlynkWifi::run() at C:\Users\User\Documents\Arduino\libraries\Blynk_WiFiManager\src/BlynkSimpleEsp32_WM.h line 692
So I commented out the line that calls the very tight DRD loop that just sits there calling millis() and the problem immediately went away.
I got exactly the same result when I went back to the ESP8266 board; comment out the DRD loop call and it works. Same thing if I enabled “#define USING_MRD true” it would hang at the MRD loop call and commenting out that call would fix the problem.
So. Absolute bare bones Blynk code, an ESP8266 board and two ESP32 boards all giving the same result. The DRD/MRD hangs the CPU.
I have no idea how nobody else seems to be having the same problem, perhaps they are just giving up, but I thought I would share my results.
Maybe I should be using the “Edgent” thing or some other library/version combination? If there is already some info on how to fix this somewhere I sure couldn’t find it. I’m pretty new to using Blynk, but not to cpp. Thoughts anyone?
