Door reed sensor
Hello everybody, I have a quick question.
All of my code is working correctly however I want to use eventor with notification widgets to alert me whenever my door is open or closed. The problem is I don’t know how I would make eventor do an equal to when the value reads back as text as seen in the code below seeing as I can only use a numerical value. Will i just have to change the text to a 1 or a 0? Thank you all for any help.
bool current = 0;
bool previous = 1;
char auth[] = "idrathernotsharethis";
char ssid[] = "lol";
char pass[] = "lol";
  pinMode(14, INPUT_PULLUP); //DOOR
void switchstate(){
  current = digitalRead(14);
  if (current != previous){
    previous = current;
    if (current == LOW)
              Blynk.virtualWrite(2, "Your door is closed.");
               Blynk.virtualWrite(2, "Your door is open!");
  switchstate();
Actually I think I answered my own question, will this cause any issues with it getting stuck in a loop or timing out?
              Blynk.notify("Door Closed");
         }     Blynk.notify("Door Opened");
If the state keeps switching, perhaps some flood error issues and missed notifications (notifications have limits to how many times a second they can be called… see link below) becasue you have that check loop running hundreds of times a second. Break the switchstate() function call out of the main void loop() and use those timers I mentioned in another topic.
http://docs.blynk.cc/#widgets-notifications-push-notifications
Limitations :
  • Maximum allowed body length is 120 symbols.
  • Only 1 notification per 15 seconds is allowed
Also check out this quick reference about timers…
https://playground.arduino.cc/Code/SimpleTimer
BlynkTimer is the same as the widely used SimpleTimer library, in that it works more elegantly than manually manipulating millis() and it is NOT dependent on a connection to a Blynk Server, and also fixes some minor issues with the original library.
A typical Interval Timer layout includes a definition, timer setup (pointing to a function) and a timer call in the void loop():
BlynkTimer Mytimer; // Sets up a timer object named Mytimer (could be any name)
Mytimer.setInterval(1000L, MyFunction);  // Goes in Setup() and will call the void MyFunction() every 1000 milis (one second - adjust to your needs).  Blynk Timer allows up to 16 of these same object named timers pointing to differing functions
void MyFunction()
// Mytimer runs stuff here every 1000 millis (one second)
Mytimer.run();  // Goes in the void loop() so the BlynkTimer library can run.
@eskrei01 Hello. This is an older topic and not everyone wants to post “finished” code (as if code is ever finished :stuck_out_tongue: always a tweek here or there :smiley: ).
If you have a current issue, please create a new topic and supply details of your issue and/or question. Thank you.
