Hello Blynkers… i’m working with arduino uno and ethernet shield for my iot projects…
i want to write some code in arduino but in “docs” said :
"Don’t put Blynk.virtualWrite and any other Blynk. command inside void loop()- it will cause lot’s of outgoing messages to our server and your connection will be terminated;* "
anyone have sollution?
SimpleTimer as per many of the Blynk examples and documented on the Arduino sites.
@Costas i want to write code for capacitive sensor… so i think we can’t use timer as well… i wan’t to write some code like:
if (capacitiveValue == LOW) {
digitalWrite (relay, LOW);
but they don’t permit me to write in void loop as usual…
help
@gabryel_rosely avoid the loop() like the plague. Probably look at attachInterrupt for the cap sensor but same rule applies, just set a flag in the interrupt routine.
You would probably get away with this in loop() when the setting is HIGH.
And with a quick digitalWrite() probably OK when LOW in loop().
There are exceptions to the no code in Blynk loop() “rule”.
Test and report back.
I have never used the cap sensors but if you use a short SimpleTimer (100ms) to keep reading for LOW then you could probably do the rest inside or outside of loop().
Use timmer function as mentioned in example
#include <Ethernet.h>
char auth[] = "58d599d309e349b49e70349f5ab23e85";
const int in1 = 2;
const int in2 = 3;
const int button = 9;
const int led = 6;
int v1update = 0;
int lastv1update = 0;
int buttonState = 0;
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
buttonState = digitalRead(button);
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
if (pinValue == 1) {
v1update = 1;
if (pinValue == 0) {
v1update = 0;
if (v1update != lastv1update) {
digitalWrite(led, HIGH);
if (v1update == 1) {
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
if (v1update == 0) {
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
lastv1update = v1update;
void sendls ()
if (buttonState == HIGH) {
Blynk.virtualWrite(V5, HIGH);
}else{
Blynk.virtualWrite(V5, LOW);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(button, INPUT);
Blynk.begin(auth);
timer.setInterval(1000L, sendls);
i do like that but i got nothing
did you have some projects like
“if your room terperature getting high , turn on fan” ?
No but i made a project on water level indicator in blynk
can you post it
Its therr on blynk community check that out go to project made wity blynk
ok
Great hope that’s help you!!!
Thanks for you all. by using “short” simpletimer finaly it’s done
SimpleTimer rocks, you can’t really do any serious Blynking without it.
